Thread started 09 Aug 2011 (Tuesday) 09:43
Does anyone have samples from the 70-300L with kenko 1.4x TC?
absplastic
Gallery: 40 photos
Aug 09, 2011 09:43 |  #1
I'm considering getting the Kenko PRO 300 DGX teleconverter for use on my 70-300mm f/4-5.6L just for reaching small birds. I've heard that it fits, and works, and with some little trick of masking off one of the pins you can trick the camera into not knowing you're at f/8 wide open and it will sometimes be able to AF in bright daylight (though I expect to manually focus).
But what I can't find are any example shots from this combo. I'd love to see some full-res shots or 100% crops especially. Thanks!
5DSR, 6D, 16-35/4L IS, 85L II, 100L macro, Sigma 150-600C
SL1, 10-18 STM, 18-55 STM, 40 STM, 50 STM
My (mostly) Fashion and Portraiture Instagram (external link)
flickr (external link) (NSFW)
moltengold
Joined Jul 2011
Aug 09, 2011 17:25 |  #2
me too
i want to see some samples
thanks
| Canon EOS | and some canon lenses
wombatHorror
Aug 09, 2011 18:03 as a reply to  @ moltengold's post |  #3
me three
(I'm getting a bad feeling this may go on "me four", "me five" until we have ended up adding the entire ownership of this lens to the list and not a one with a kenko 1.4 hah)
aboss3
Aug 09, 2011 18:09 |  #4
+1 for samples w/Kenko :D
Gear | My gear is changing faster than I can update the signature
VoyageEyewear (external link)
moltengold
Joined Jul 2011
Aug 09, 2011 21:33 as a reply to  @ aboss3's post |  #5
Here is the sample
an example of the DGX 1.4 TC in action on the 70-300 LIS + 7D
wombatHorror
Aug 09, 2011 23:17 |  #6
I'm pretty sure that is not a 100% crop and re-sizing 10-18MP down to like 1/4MP makes anything look sharp as heck. SO I don't think that really tells one anything at all. (if it actually is a 100% that would be insane though, but I really doubt it could be)
phreeky
Aug 09, 2011 23:54 |  #7
http://forums.dpreview​.com …age=38097672&ch​angemode=1 (external link)
wombatHorror
Aug 10, 2011 14:17 |  #8
doesn't look that bad, although the NR+sharpening making it a little hard to judge
but it hints that it does do better than upscaling would
Gascar
Joined Aug 2011
Aug 10, 2011 17:10 |  #9
My AF works without masking any pins off. Anyone else?? Hunts a bit, close-up, but only on difficult subjects. Yes it's slightly better than cropping & enlarging, but not a lot.
phreeky
Aug 10, 2011 17:23 |  #10
wombatHorror wrote in post #12911240 (external link)
I've never seen a TC combo that is worse than upscaling, once you process both shots.
Gascar wrote in post #12912208 (external link)
Does the 70-300L even have the pins to mate up with the TC? If Canon haven't stated that it's compatible with TCs then it probably wont have the pins and therefore there is no need to tape the pins. It also means that it wont report the correct aperture and focal length, unless you're using a Kenko DGX TC (I'm not sure there are any others that do this).
Gascar
Joined Aug 2011
Aug 10, 2011 17:43 |  #11
It's the current Kenko - er Pro 300 DGX. It's got 5 + the 3 power pins on the back and more on the front - more than the lens!
The camera reads the aperture right ( ie adds a stop) and gets the FL right too.
phreeky
Aug 10, 2011 17:45 |  #12
Gascar wrote in post #12912366 (external link)
Oh yep that's a feature of the new Kenko DGX TCs. They seem to intercept the data such that AF keeps working but the final EXIF data is correct. Quite handy indeed, I use one on my 400 F/5.6 a fair bit.
Gascar
Joined Aug 2011
Aug 10, 2011 17:54 as a reply to  @ phreeky's post |  #13
Here's a pic at 300mm f/5.6, 600D. Only the center box is in focus. DOF is ridiculously shallow. I think that's OK, if I'm using it for a bird in a tree I'll only need the middle anyway :)
http://img20.imageshac​k.us/img20/9496/img457​1bf8.jpg (external link)
wombatHorror
Aug 10, 2011 18:33 |  #14
phreeky wrote in post #12912267 (external link)
I actually found 2x TC III was worse than uspcaling, on 135 f/2, kinda surprised me (maybe if you stopped, way, way, WAYYYYYY down it would be different)
i can't imagine the 1.4x would do ,much for the old 75-300 IS, etc.
wombatHorror
Aug 10, 2011 18:35 |  #15
Gascar wrote in post #12912437 (external link)
thanks
what camera settings?
6,114 views & 0 likes for this thread, 7 members have posted to it.
1503 guests, 130 members online
