Thread started 09 Aug 2011 (Tuesday) 13:43
PW Plus II Compatible Flash
Michelle ­ Brooks ­ Photography
Joined Sep 2009
Aug 09, 2011 13:43 |  #1
Hey, all; I am looking for a used flash to use for OCF and need it to be compatible with my Plus II Pocket Wizards; by compatible I mean I also need to be able to use a sync cord with it. Will a 430 EXII or 550EX fit the bill? Thanks!
Michelle Brooks Photography (external link) | Flickr (external link) | Facebook (external link) | Twitter (external link)
eduardofrances
Aug 09, 2011 19:27 |  #2
Michelle Brooks Photography wrote in post #12904804 (external link)
As long as you have a PC to 3.5mm sync cable you'll do fine, I can't remember if the PWs include this cable in the box but if it doesn't check Flash Zebra http://flashzebra.com/ (external link) Lon has all the sync cables one could need at great prices and great service.
http://flickr.com/phot​os/eduardofrances/ (external link) :D
EdW
Joined Apr 2011
Aug 09, 2011 19:27 |  #3
I have the 550EX. The 550EX doesn't have a sync port built-in so you will need a hotshoe with either a sync port or an attached sync cable (like the one from FlashZebra which is on my to-buy list). You will have to make sure to get the hotshoe that fits the flash brand. FlashZebra has them available for some of the popular brands.
http://flashzebra.com/​products/0126/index.sh​tml (external link)
Joined Sep 2009
Aug 10, 2011 10:17 |  #4
EdW wrote in post #12906562 (external link)
This is what I was wanting to know; I want one with the built in sync port. So, is the 580EX the only line that has one?
sdipirro
Aug 10, 2011 11:01 |  #5
The 580EX II has one. The original 580EX does not have a synch port. However, I bought the replacement 580EX foot with synch port from flashzebra, and the swap was easy, and I've been using my 580EX off-camera with PW II's for a while now. Another option to consider is the FlexTT5 if you want to use the off-camera flash with ETTL.
Cameras: 1DX, 1D4, 20D, 10D, S90, G2
Lenses: Canon 10-22mm, 16-35mm f2.8L II, 24-70mm f2.8L, 70-200mm f2.8L IS, 300mm f2.8L IS, 200mm f2L IS, 50mm f1.4, 50mm f1.2L, 85mm f1.2L, 1.4x TC, 2x TC, 500D macro, Zeiss 21mm
Lighting: 580EX, Elinchrom 600 RX's, D-Lite 4's, ABR800, 74" Eli Octa, 100cm/70cm DOs, Photoflex Medium Octa and reflectors, PW's, Lastolite Hilite, Newton Di400CR bracket
Joined Sep 2009
Aug 10, 2011 11:48 |  #6
^^THanks, I appreciate your information!^^
ROGERWILCO357
Joined Sep 2009
Aug 10, 2011 15:16 |  #7
yeah the 430 has no port and had to buy the hot shoe adapter from flash zebra problem solved now any flash will do.
EOS 5DMKII gripped;EOS 7D;30D:Rebel Xti Digital;24-105L,70-200 f/2.8L.II,85mm f1.2L.II,16-35Lmk2, SP AF90mmF/2.8DI,28-135mm x 2,580EX II-430ExII with Pocket Wizards II,(Adobe CS5)
1,338 views & 0 likes for this thread, 5 members have posted to it.
1596 guests, 137 members online
