Thread started 09 Aug 2011 (Tuesday) 15:43
Getting gray out of skin
RebelChick
Aug 09, 2011 15:43 |  #1
Despite a using a gray card to calibrate my camera, I seem to "occasionally" get gray skin tones due to improper exposure, obviousely. Sometimes I get lucky in PS with fixing it, but never find a sure fire way. Any tips?
Here is a photo for you to play with to see what I mean. Please explain what you did, thanks :D
please excuse the tilt :) this was a complete "Oops" shot, and I literally was falling over a huge rock as I took this haha.
Cortney B Photography (external link)
CBP Facebook Fan Page (external link)
chrisa
Gallery: 184 photos
Aug 09, 2011 16:14 |  #2
IMAGE: http://farm7.static.flickr.com/6083/6027129444_a159325716_z.jpg
PixelMagic
Aug 09, 2011 16:19 |  #3
It certainly would help if you posted a larger image with the original color profile embedded.
As Chris A demonstrates Curves is one way to go but I wouldn't use such a brute force method. Instead I'd use the Select > Color Range command to select the skin only, then click on a Curves adjustment layer. This will automatically reveal just the skin and mask off the rest of the photo. From there its a simply matter of adjusting the individual RGB curves until you remove the color cast and get something that is pleasing to your eyes.
RebelChick wrote in post #12905518 (external link)
Hermes
Aug 09, 2011 16:27 |  #4
Set photoshop to open JPEGs in camera RAW. Then you can just use the temperature and exposure sliders to warm and brighten the shot.
Wilt
Aug 09, 2011 17:35 |  #5
Here is simple use of Color Balance adjustment, along with Brightness & Contrast adjustment, in Paintshop Pro.
Or using a real PHD one automagic button, 'One Step Photo Fix'...
tkerr
Aug 09, 2011 17:54 |  #6
Use curves and set the black point on her dress on a curves adjustment layer. Then you can fine tune it from there if you want. Maybe increase the Vibrance a little.
Or a little warmer.
Tim Kerr
F1, try it you'll like it.
HappySnapper90
Aug 09, 2011 21:06 |  #7
This image was very under exposed, and the white balance is off (probably due to all the green in the image). Here's what I did using Lightroom with "linear" tone curve.
6,551 views & 0 likes for this thread, 7 members have posted to it.
1314 guests, 122 members online
