Just noticed the rubber grip on my 7D had come unglued in a small section. Guessing this has happened to others. What have people used to glue this back on?
Adam
Aug 11, 2011 20:45 | #1 Just noticed the rubber grip on my 7D had come unglued in a small section. Guessing this has happened to others. What have people used to glue this back on? Canon 5Dm3, Fuji X100T, Fuji X-T1, Fuji X70
eg6turbo Senior Member 388 posts Joined Oct 2009 Location: San Francisco More info | Aug 11, 2011 21:51 | #2 if its under warranty i would just send it back to canon. Thats what i did for the rubbber around the grib right next to the shutter button and they replaced the whole piece with a better made one for free=) hope this helps | Canon Rebel T2i Gripped | EF-S 17-55 2.8 IS USM | EF-S 18-55 IS | EF-S 55-250 IS | EF 50 1.8 MK II | EF 85 1.8 USM | Speedlite 430EX II |
DarthVader There is no such thing as Title Fairy ever 6,513 posts Likes: 42 Joined Apr 2008 Location: Death Star More info | Aug 11, 2011 21:54 | #3 Never happened to me. Do you have acid sweat ? Nikon/Fuji.
Aug 11, 2011 21:57 | #4 I had this problem with a Zeikos grip.... After several other failed attempts, I got some super glue made by Gorilla Glue.... That stuff works like a charm. Canon 5dmkIII, Sigma 15mm f/2.8FE; 35mm f/1.4; Canon EF70-200 f/2.8L IS II; --- YN560 x 7
sbattey Goldmember 1,250 posts Joined Mar 2011 More info | Aug 11, 2011 22:00 | #5 Permanent banNever heard of this on the 7d. Canon 7D | Canon 50mm f/1.4 | 430EX II
ROGERWILCO357 Goldmember 1,551 posts Likes: 1 Joined Sep 2009 Location: michigan More info | Aug 12, 2011 00:37 | #6 wow have had mine since it came out and have had no issues with the grip or the camera.. EOS 5DMKII gripped;EOS 7D;30D:Rebel Xti Digital;24-105L,70-200 f/2.8L.II,85mm f1.2L.II,16-35Lmk2, SP AF90mmF/2.8DI,28-135mm x 2,580EX II-430ExII with Pocket Wizards II,(Adobe CS5)
dudemanppl Senior Member 303 posts Likes: 12 Joined Jun 2009 Location: Arcadia, CA More info | Aug 12, 2011 00:46 | #7 DON'T SUPERGLUE ANYTHING. If you do, you'll be screwed if you need repairs done on it.
mondayshift Goldmember 2,301 posts Likes: 730 Joined Apr 2011 Location: NC More info | Aug 12, 2011 01:43 | #8 happened on my 60D, sent it in to Canon for the warranty. if it was not under warranty i would of just super glued it. “Sucking at something is the first step towards being sorta good at something.”
dudemanppl Senior Member 303 posts Likes: 12 Joined Jun 2009 Location: Arcadia, CA More info | Aug 12, 2011 02:49 | #9 If you superglue the rubber, they can't take apart the camera... Trust me, I've taken apart a lot of cameras.
I picked up the 7D shortly after it came out. So not under warranty, I still may send it in though I'll get the dial replaced as well with the new dial. Canon 5Dm3, Fuji X100T, Fuji X-T1, Fuji X70
Aug 12, 2011 06:23 | #11 You can get contact adhesive in a tube, the type that you spread a thin coat on each surface and wait a while before pressing the parts together. In the UK the stuff is called Thixofix. Ian
hitek Member 152 posts Joined Jul 2011 Location: Ohio More info | Aug 12, 2011 06:28 | #12 I hope it doesn't happen to mine! Gear: 6D ii l BG-E21 l Tamron 28-75 l Canon 17-40L l Canon 50 1.8 l ST-E3-RT l Canon 70-200 f4 IS l 600EX-RT l Manfrotto 055XPROB l 322RC2 Head l GlideCam
| Latest registered member is Monkeytoes 1331 guests, 169 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
