FORUMS Photography Talk by Genre Macro Talk
Thread started 12 Aug 2011 (Friday) 15:36
Reversing Ring Question
ebert
Joined May 2011
Aug 12, 2011 15:36 |  #1
Hello all!
So I just started playing with some reversing rings. I am wondering about the effects of the amount of space between both lenses through either adapter ring thickness, or using lenses with their front element recessed vs non-recessed? Does the space between the optical elements make a huge difference?
Right now I'm not sure if I should ebay reversing rings with 2 male threads, or get step down/up rings + couplers. Same for reverse EF mounts. You can get a mount per filter size, or just get one filter size and use step up/down rings to adapt it to your other lenses.
macro enthusiast | Gear and Feedback
LordV
Aug 13, 2011 02:06 |  #2
ebert wrote in post #12924264 (external link)
Hello all!
I don't think the gap between the lenses matters much at all. It certainly does not seem to affect the magnification you get.
Brian v.
Macro Hints and tips
ebert
Joined May 2011
Aug 13, 2011 18:54 |  #3
thanks for your help, brian :)
1,084 views & 0 likes for this thread
Latest registered member is bluezurichart
778 guests, 249 members online
