Thread started 15 Aug 2011 (Monday) 08:13
Tech question on a 430 diffuser
Mark1
Aug 15, 2011 08:13 |  #1
I had my 430exII fall off a stand Sat night. The only damage done was the diffusion panel broke off. I think this is the second time it has ever been out. So it is not really a problem. However the problem is, with the carriage that holds it extended, I cant set the zoom manually or automatically .
So the question is if I push the tab that holds the diffusor, back down, will I regain zoom control or is the sensor on the panel it self?
Right now it is fully extended. So it will be literally a 10 second fix if I have to replace the diffusor. But will not spend the time or money if I can make it work without the panel.
Mark1
Aug 15, 2011 16:07 |  #2
I ended up just shoving it back in. It still hooks on enough to pull it out if I have to. But I doube I will.
klr.b
Aug 15, 2011 19:25 |  #3
If it's like the other flashes, you'll need to disassemble the head to change the panel.
gordon
Gear and Feedback
778 views & 0 likes for this thread, 2 members have posted to it.
1067 guests, 104 members online
