dougy_8505 wrote in post #12943404
ya im going to use as is and replace it with a smaller mm lens..
Stone which do u use more that 30mm or the 50mm...
i have a 18-125 and i find myself shooting alot at around 25 or so, so i was thinking i might like a prime in the 20 to 30 range
Depends on what you are shooting I guess? The 30mm on a crop is a standard prime, the 50mm is a good lens for portraits on a crop body. Keep in mind, the sigma 30mm is designed for crop camera only, it will not work on a full frame body. If you think you will upgrade to FF in the short future, consider this factor~!
