Thread started 16 Aug 2011 (Tuesday) 15:15
Help with off camera flash shot
Bpesca
Aug 16, 2011 15:15 |  #1
Hello,
So I have a wedding this weekend during the day near the Boston skyline. It ends at 5PM but the bride and groom are hanging around town to party it up. I have convinced them to come out a bit later for a night time skyline shot.
My idea is to use this exact spot in the link below and put the B&G in front of it with an off camera flash (non-ETTL) behind them to light up the vail. Pretty much combine this pic
with the background I've linked below
I'm fairly new to the off camera flash so I'm looking for some input. I assume just meter for the skyline and start the flash behind them at 1/2 power and go from there? If anyone has any ideas or input on how to speed up my "finding the perfect setting" it would be greatly appreciated. FYI the B&G are good friends of mine and I have warned them that this might take several takes to get it right and they were fine with that.
Many thanks!
http://www.flickr.com …0/sizes/l/in/ph​otostream/ (external link)
1Ds Mark II
24-70L
70-200L f2.8 II
Brian Pescatore Photography Facebook (external link)
Peacefield
Aug 16, 2011 20:05 |  #2
If you already know where you're going, why not go at the same time of evening a day early and do some test exposures?
Robert Wayne Photography (external link)
5D3, 5D2, 50D, 350D * 16-35 2.8 II, 24-70 2.8 II, 70-200 2.8 IS II, 100-400 IS, 100 L Macro, 35 1.4, 85 1.2 II, 135 2.0, Tokina 10-17 fish * 580 EX II (3) Stratos triggers * Other Stuff plus a Pelican 1624 to haul it all
picturecrazy
soft-hearted weenie-boy
Aug 16, 2011 21:09 |  #3
It's hard to say what flash power you are going to use without knowing anythhing else. To me, 1/2 power sounds insanely high, unless you bring a tripod, shoot at ISO 100 f/11. Set up your background exposure, and the rest you will have to do with flash. You may have to bring two flashes because it's unlikely that you will get a balanced exposure on the bride and groom in relation to the sky. It might end up that you only get a rimlight on the couple without enough detail on the rest of the bodies. In that case you might need just a tiny touch of fill flash.
-Lloyd
The BOUDOIR - Edmonton Intimate Boudoir Photography (external link)
Night and Day Photography - Edmonton Studio Family Baby Child Maternity Wedding Photographers (external link)
Night and Day Photography - Edmonton Headshot Photographers (external link)
Facebook (external link) | Twitter (external link) |Instagram (external link) | Gear
Tiberius
Aug 16, 2011 22:12 |  #4
Bpesca wrote in post #12946555 (external link)
Many thanks!
Yeah. Set your camera and flash to full manual. Expose the camera for the background, then position your lights and use flash exposure to get the subjects properly exposed. Check the link in my signature "Using Manual Flash".
My photography website!PHOCAL PHOTOGRAPHY (external link)
Red ­ Tie ­ Photography
Aug 16, 2011 22:53 |  #5
i was thinking what Lloyd said. I often do shots similar to this and my setup is pretty easy. Ill use my 35L or 50L, start at about ISO 1600, f2.2ish, 1/125th and see where that takes me. Then I will set my flash behind them at about 1/32-1/8th, and then use another flash off camera through an umbrella to fill them in. Feel free to check out my blog, there are quite a few shots I do towards the end of the weddings that use this technique.
Bryan
Gear List (external link)
San Diego Wedding Photography - Red Tie Photography (external link)
Red Tie Photography Blog (external link)
caught14
Aug 19, 2011 08:36 as a reply to  @ Red Tie Photography's post |  #6
Just reaffirming what others have said:
1) Take a couple test shots (without firing any external lights) and set your exposure for the background. Yes your subjects will be dark, but that doesn't matter since you will worry about lighting them in step 2. Start with your shutter speed around 1/160.
2) Set your remote flash(es) in manual mode and start at about 1/16. Fire a test shot and see if you like it. Dial the flash power up or down based on the look you want to achieve. One light from behind them will give them a nice rim light and silhouette. Use multiple lights if you want to get more creative (ie, have different angles of rim light or if you want to light the front side of them as well.)
3) Drag your shutter if you want more ambient light in the background.
Good luck! I'd recommend practicing this before trying on a client for the first time. On the day of, just work with your settings and the couple until you find what looks good to you.
Colling Photography (external link)
Cameras & Lenses - Canon 5DMkII x 3 | 30D | 24
L | 35L | 45 TS | 50L | 85IIL | 135L | 16-35IIL | 24-105L | 70-200L
www.collingphotogaller​y.com (external link)
1,445 views & 0 likes for this thread, 6 members have posted to it.
1177 guests, 175 members online
