Thread started 20 Aug 2011 (Saturday) 20:09
More High Speed
Dermit
Joined Nov 2005
Aug 20, 2011 20:09 |  #1
1.
IMAGE: http://www.pbase.com/image/137390215.jpg
2.
IMAGE: http://www.pbase.com/image/137390216.jpg
3.
IMAGE: http://www.pbase.com/image/137390217.jpg
4.
IMAGE: http://www.pbase.com/image/137390219.jpg
5.
IMAGE: http://www.pbase.com/image/137390220.jpg
5DmkII, 5DmkIII, 5DS R, 15mm, 16-35 f/2.8 II L, 100 Macro f/2.8 L, 70-200 f/2.8 L IS, 85 f/1.8, 580EX II, 580EX, 550EX
http://www.pixelcraftp​hoto.com (external link)
MikeFairbanks
Aug 20, 2011 21:16 |  #2
Genius.
Tell us more. Incredible.
Thank you. bw!
goldboughtrue
Aug 20, 2011 23:17 |  #3
#4 is really cool! I like that the top of the post is visible so the blue water is surrounding it. Plus, the yellow balloon and blue water are a perfect contrast.
http://www.pbase.com/g​oldbough (external link)
5D II, Canon 100 macro, Canon 70-200 f/4L, Canon 24-105 L, Canon TS-E 45, Sigma Art 35mm f/1.4
kraaazymike
Aug 20, 2011 23:38 |  #4
These all came out great! Nice work
bboehm
Aug 20, 2011 23:42 |  #5
Love HS photography. Nice work.
7D, 50D, EFS 17-85mm IS, 24-70mm f/2.8L, 50mm f/1.2L, 70-200 f/2.8L IS II, 2X Extender III, Calumet Genesis 400, Speedlite 430EX, Pocket Wizards
Dermit
Joined Nov 2005
Aug 21, 2011 21:08 |  #6
MikeFairbanks wrote in post #12970151 (external link)
Genius.
Here is a shot of my 'studio' I took in the middle of the chaos...
IMAGE: http://www.pbase.com/image/137418820.jpg
So the routine goes like this...
I set the flashes on manual and dial them down in power. For this shoot I dialed them both to 1/128th power. Low power equals very fast durations which is important for high speed photography.
Before shooting I have to get a pre-focused setting on the camera. So the 'target' you see in the upper-right of the image I swing down into place where the action will be and use auto focus on that. I also use the target to set the exposure for the shot. Once locked on for focus and exposure I switch to manual focus, mark the floor directly below where the target is, then swing the target out of place. This I only do once for all similar shots.
Since the flashes are set low power and need to be there any adjustments for exposure needs to handled by adjusting ISO or aperture, or moving the flashes closer or further from the action. Aperture should be pretty tight for more DOF, I used somewhere between f/11 and f/16.
The microphone to trigger the event is held on top of the flash on the left in this picture. You look close you can see the wire running down to the left to the Stop Shot device.
The Stop Shot I played with different delays ranging from 1 ms to 14 ms depending on what effect I wanted to see.
So to initiate a shot here's the steps...
1. Turn off the lights in the room. (Notice black plastic over the windows) This makes it dark, but there's just enough light to see enough to not trip over things.
2. Open shutter. I use a cable release with camera in bulb mode. This could also be done by just setting a long shutter lie 15 to 20 seconds. Most my shots took about 10 - 15 seconds.
3. Grab a water balloon and quietly walk to the 'action' (do not want to trip the audio trigger).
4. Pop balloon. I used a push pin attached to my right thumb by a band-aid (hides it better than tape would have).
5. If audio trigger is set right the flashes trigger.
6. Walk back to cable release and close shutter. If you use long shutter instead and it has not closed yet on it's own, go block the lens with lens cap or similar. The less ambient light in the better.
This should get it. Every shot is different which makes it fun. I evaluate the shot and decide if I want more, or less delay for the next shot. Another thing that matters is how full you fill the balloons. Fill them tight and the pop faster.
celowbe
Aug 22, 2011 07:49 |  #7
Awesome setup and shots..
Gear list
Dermit
Joined Nov 2005
Aug 22, 2011 08:21 |  #8
I should mention that for the shots of the balloons dropping on the railroad spike I brought in a table, which is not shown in the setup shot here.
I am always looking for new ideas to destroy water balloons, so I am taking requests. One thought I had recently was to do a sports themed destruction. Like hitting them with a bat, tennis racquet, golf club, etc. I may have to take those shots outside into the driveway though which will limit me to night shots only.
walism
Joined Jul 2011
Aug 22, 2011 09:20 |  #9
No 4. the blue water and yellow ballon is nice.. thanks for sharing.
Wal..
celowbe
Aug 22, 2011 20:44 |  #10
Agree..sport shots destroying balloons wouild be a good shot..Will be staying tuned to ur threads, they sound too interesting..
Gear list
Clean ­ Gene
Joined Nov 2010
Aug 22, 2011 23:46 |  #11
Dermit wrote in post #12977246 (external link)
I realize that this may be a bit dangerous and perhaps not really feasible. But have you thought about filling the balloons with a highly flammable liquid, and then adding fire to the equation?
I'm imagining something sort of like what you already showed us. Except that it's also on fire. That seems like it might be really cool.
Of course, you would have to be able to make sure that you can do it safely, because I would hate to see anyone here getting hurt. Also, I'm not even sure if that'd even work. But I think it could make for a really cool picture.
Dermit
Joined Nov 2005
Aug 23, 2011 20:28 |  #12
Clean Gene wrote in post #12982502 (external link)
I've thought about this and am not sure about the execution of it yet but have not ruled it out. The piece that complicates it is that fire gives off light, that can be tricky to fit it in with the exposure in a way that does not spoil the shot. The fire part either has to travel to the fuel fast, or ignite the fuel fast. If you simply try to introduce the target to a fire source that is just burning in the shot while the shutter is open it will mess with the exposure of the target too much. So my gears are turning... but the garage is out, this will have to done somewhere not near any structures or other flammables.
I'm ­ Sasquatch
Gallery: 44 photos
Aug 24, 2011 00:10 |  #13
Excellent idea and execution, Dermit. I really like it. Thanks for sharing your set up and the tutorial. I'd love to give this a try some time. Adding an audio trigger to my gear list is sounding (pun intended) like a good move.
Have a wheelie nice day!
CamDiver
Aug 26, 2011 18:07 |  #14
I think I need to get me one of those cool Water Balloon Carrying Devices. Are they from Canon?
Sumatra Macro Photography Trip, July 2016 (external link) -"A man is only as big as the dreams he dares to live"
Canon 5DMkIII - MPE65mm - Venus 60mm f2.8 - Tamron 90mm f2.8 - Tamron 180mm - Canon 15mm f2.8 - f3.5 - MT24EX - Nikkor 14-24mm f2.8 - Nikkor 50mm f1.4 - Velbon Mag Slider - Novotech - Manfrotto & Gitzo - SYRP Genie & Magic Carpet for Timelapse.
Dermit
Joined Nov 2005
Aug 27, 2011 22:11 |  #15
CamDiver wrote in post #13005762 (external link)
Yes, But this one in the picture is an "L" version (notice the off-white color) and tends to be very expensive for most people's taste. But the quality is great!
2,713 views & 0 likes for this thread, 10 members have posted to it.
More High Speed
1470 guests, 139 members online
