Thread started 21 Aug 2011 (Sunday) 08:09
Avoiding green tint from overhead trees
Michelle ­ Brooks ­ Photography
Joined Sep 2009
Aug 21, 2011 08:09 |  #1
So what's the secret -- in camera or out -- of avoiding or getting rid of the green tint that can result in people's skin from being surrounded by leafy green trees? I know the obvious answer-- don't put them there! But sometimes for outdoor weddings the only shade is amonst trees. Thanks!
Michelle Brooks Photography (external link) | Flickr (external link) | Facebook (external link) | Twitter (external link)
rral22
Aug 21, 2011 08:26 |  #2
I either shoot a custom WB or do it in post. Mostly post. Everything is shot Raw. Sometimes, if I am pressed for time, I will just take a shot with a sheet of white paper in it to use as a reference for the post processing.
Joined Sep 2009
Aug 21, 2011 08:44 |  #3
rral22 wrote in post #12971805 (external link)
What program do you use for processing & could you explain what you do in post processing to fix the tint? If it's not too complicated to type. :)
chauncey
Aug 21, 2011 08:53 as a reply to  @ Michelle Brooks Photography's post |  #4
There are a ton of tutorials out there...http://www.youtube.com …1&list=PLD8F1DE​14441B1EF6 (external link)
D ­ Thompson
Aug 21, 2011 09:27 as a reply to  @ chauncey's post |  #5
A quick way in PS, although sometimes it takes a little playing around with the sampled color for better results. Then, there has been a few times this just didn't work at all for some reason :confused:. As anything in PS, there are many ways to do things.
Use the eyedropper to click where should be neutral. Fill a new blank layer with that color. Invert. Change blend mode to Softlight (sometimes Overlay) and apply a mask to where you want to get rid of the cast. Can adjust the layer opacity a bit also.
Dennis
Canon 5D Mk III 5D 20D
I have not yet begun to procrastinate!
D ­ Thompson
Aug 21, 2011 09:46 as a reply to  @ D Thompson's post |  #6
Another way is to use a curves adjustment. Place a sample point where should be neutral. Adjust each channel to neutral and mask as needed.
Dennis
rral22
Aug 21, 2011 10:12 |  #7
As D Thompson said, the eyedropper tool is your friend. Lightroom does most of it; DPP does the rest.
Get yourself something truly white that you take to shoots, and then you can use a shot of it to get the adjustments you need. It's a custom WB after the fact.
Joined Sep 2009
Aug 22, 2011 09:00 |  #8
Thanks, everyone! Gonna try that white paper trick; or I guess a gray card would work too?
Curtis ­ N
Master Flasher
Aug 22, 2011 10:13 |  #9
White paper is better than nothing... maybe. Sometimes it has bluing and isn't really white.
A couple options:
WhiBal card
Photovision calibration target
These things are just tools. Remember, the "correct" white balance is not necessarily the "best" white balance. But they'll give you a benchmark to start from.
2,183 views & 0 likes for this thread, 5 members have posted to it.
1596 guests, 137 members online
