tman2782 wrote in post #12975769
^This
I haven't used an external flash yet, so thought I'd learn something while adding for the OP's benefit because that is pretty much what he's trying as well albeit in a different lighting situation.
I would assume E-TTL would react and power up flash to compensate otherwise wouldn't that defeat it's purpose?
This is the tricky bit with flash; you're really doing two exposures at once when using it.
Ambient light: Controlled by aperture, shutter speed and ISO
Flash light: Controlled by aperture and ISO; basically ignores shutter speed
So, you're getting the same amount of light contributed to your image at:
f/4, 1/100, ISO 200
f/4, 1/200, ISO 200
The difference there is the ratio of how much ambient light contributes to the image vs how much light the flash contributes to the image.
If the lighting is low enough, then either setting is going to get ALL of its light from the flash and produce the same exposure; regardless of the different shutter speeds.
