Thread started 22 Aug 2011 (Monday) 10:47
100 macro vs. 100 L macro
chinorider
Aug 22, 2011 10:47 |  #1
I have decided I would like to try some macro work and was wondering what the collective thoughts were on the 2 Canon 100 macro lens. Is the L worth the xtra $$$ ? Looking on POTN shows both take great images.
Thanks for any input.
Moved to micro 4/3 system
rick_reno
Aug 22, 2011 11:19 |  #2
I've got both of them. No detectable IQ difference between them. L "feels" better and has IS. If IS or the build quality is important to you, get it. If not, get the non-L.
a_roadbiker
Aug 22, 2011 12:15 |  #3
You don't need IS for macro photography because you should be using a tripod anyway...
I have the non-L and it provides great results. There are plenty of threads on this exact subject in here, so if you poke around a bit you will find all kinds of opinions (which generally agree with what chinorider and I have posted).
Jim
Jim
Click here to see a list of My Stuff
Visit my flickr (external link)
Like me on Facebook (external link)
www.jmaurophoto.com (external link)
paddler4
Aug 22, 2011 12:21 |  #4
If you search, you will find this question beaten to death already.
Rick is right, IMHO.
I actually destroyed a 100L (it fell into a lake!) and replaced it, which is an indication of my preferences. The IS is in my opinion worth it. First, you can use the lens for non-macro purposes, and 100mm on a crop sensor is plenty long enough that IS helps. Second, I disagree with a_roadbiker--there is lots of macro work for which a tripod is impractical. If you are going to do handheld macro work, the hybrid IS in this lens will help somewhat (although not a great deal). However, it probably won't matter if your are doing handheld work with flash, and if you are doing work on a tripod, the IS will be worthless.
I do a lot of macro work with a monopod. The camera moves a fair amount (at least with my unsteady hands), but I have never done an A/B comparison to see whether the IS helps under those circumstances. I'm guessing not, as the motion is nearly perpendicular to the sensor.
Check out my photos at http://dkoretz.smugmug​.com (external link)
davidnholtjr
Aug 22, 2011 12:22 |  #5
Get the Non-L and use the extra cash for something else. The lens is super sharp.
Later, David
flickr (external link) | Gear List & Feedback
windpig
Chopped liver
Aug 22, 2011 12:24 |  #6
rick_reno wrote in post #12978287 (external link)
Although I don't have the non-L any longer, I would agree with this.
Go ahead, spin the wheel.
wombatHorror
Aug 22, 2011 12:29 |  #7
chinorider wrote in post #12978105 (external link)
L has slightly better mico-contrast. It's not a huge deal though.
The L is a bit faster, so instead of f/2.8 it seems more like f/2.5 (not that this matter when using it for macros at all though).
The IS can be nice to have at times. If bugs are moving it doesn't help or if the plant they are on is blowing around even a little it doesn't help but for stationary bugs and flower it can help. I actually got some 1/40th shots at 1:1 by firing 8fps bursts and picking out the good frame.
this was natural light, 1:1 or nearly so and somewhere around 1/40-1/60th (used AI Servo AF and 8fps drive and picked best frame, even with IS, at 1:1, certainly get many blurred frames especially since I am REALLY bad athand-holding):
but you still need a flash since lots of times bugs move all over or the plant blows around or there is not direct sun
the IS helps even more for flowers where you may not be at 1:1 and they are always still unless there is a breeze. granted you could tripod any flower shot, although sometimes it is a lot more fun to not have to bother
using a tripod can be very tricky for many bugs, since by the time you finally set it up and move it into perfect focus the bug is gone, sometimes they only sit still for 1 second and sometimes never, of course in the latter case IS won't help
IS can help steady the frame for easier composition though so even if you are not using it to stabilize the shot itself it can make framing easier without your hands shaking the view all over
I like the L better, of course there is a big premium.
wombatHorror
Aug 22, 2011 12:36 as a reply to  @ wombatHorror's post |  #8
100% crops
difference is easier to see if you save the images and flip back and forth in image viewer
non-L at f/2.8 and MFD:
L exposed 1/3 stop less long but still looks about as bright, also at f/2.8 and MFD:
the transition from black to white is just a little crisper with the L, just a little bit better microcontrast
they have a different color rendition as they were taken using fixed WB and identical lighting but the color looks different
chinorider
Aug 22, 2011 13:50 |  #9
Thanks for all the comments. Seems like I (a beginning DSLR amateur with tons of film experience) would be happy with the non L.
amfoto1
Aug 22, 2011 14:04 |  #10
I see you are using 7D... An interesting feature with either of these lenses, at macro magnifications set the camera to AI Servo and the AF acts sort of like a form of image stabilization. It's unique to 7D, as far as I know. What it does is use a more frequent sampling mode when certain macro lenses (limited to Canon's own) are attached and focused to macro distances. This helps keep shots in focus, such as when the camera moves slightly closer to or farther from the subject. Unlike IS, it can help with slight subject movement, too, such as when a flower moves a little in a breeze. You can do similar using AI Servo with other Canon models when shooting macro, but the 7D has an enhanced focusing system that can make it more capable for macro shooting.
Also, the 7D's Spot Focus can be very handy for macro work, though it is a little slower than some of the other focus modes.
I just wish the 7D had an articulated LCD screen, for low angle work (I manage with an angle finder, though).
I'm still using the non-L, non-IS 100mm and have no plans to upgrade. Whichever you get, I highly recommend the optional tripod mounting ring. The Canon ring is pretty pricey. You can get nearly identical third party t'pod rings off eBay or elsewhere for much less $.
I need to go look at the 100L again, or maybe rent it for a week. I might be wrong but personally didn't think it's build quality was any better than the earlier model (which seems pretty identical build to the 180/3.5L). The newer lens gets one more aperture blade (9 vs 8 in the USM lens), though I'm not sure it they are curved blades in either lens or if either lens offers better bokeh than the other.
There are some excellent third party alternatives: Tamron 90/2.8, Tokina 100/2.8, SIgma 105/2.8. AFAIK, though, only the Canon are internal focusing (IF), which means they don't change length when focusing (but are larger to start with). Also, AFAIK, none of the other manufacturers' lenses can be fitted with a tripod mounting ring (some of their longer 150mm or 180mm macros come with t'pod rings, though).
Just starting out with macro, eventually you will probably want to try using flash with it. Even with good techniques, tripods, monopods, IS, higher ISO-capable cameras and all, it's always a struggle to balance adequate shutter speed with a small enough aperture, due to the very shallow depth of field common at macro magnifications. There are macro specific flashes (I might recommend a twin light for most macro 2:1 or less magnification, a ring light for 1:1 and greater magnification) but you really don't need to go to this expense initially. Just about any single, standard, eTTL-capable flash can be used... Just get an off camera shoe cord so you can position it near the subject, and perhaps put a layer or two of white gauze bandage over the flash head to reduce it's output a bit. This acts like a "huge softbox in the sky" with tiny subjects. If needed, you can use reflectors for some shadow fill. Try making a small reflector from aluminum foil on a piece of cardboard, or just white cardboard, or perhaps metallic posterboard in gold or silver.
5DII, 7DII(x2), 7D(x2) & other cameras. 10-22mm, Tokina 12-24/4, 20/2.8, TS 24/3.5L, 24-70/2.8L, 28/1.8, 28-135 IS (x2), TS 45/2.8, 50/1.4, Tamron 60/2.0, 70-200/4L IS, 70-200/2.8 IS, 85/1.8, Tamron 90/2.5 Macro, 100/2.8 USM, 100-400L II, 135/2L, 180/3.5L, 300/4L IS (x2), 300/2.8L IS, 500/4L IS, EF 1.4X II, EF 2X II. Flashes, studio strobes & various access. - FLICKR (external link) - ZENFOLIO (external link)
chinorider
Aug 22, 2011 15:23 |  #11
Many thanks Alan...very good info for me to consider.
wombatHorror
Aug 22, 2011 16:10 |  #12
amfoto1 wrote in post #12979245 (external link)
yeah it goes into hyper 2x speed AF when in that mode on the 7D
Does it really need the ring?
The lens is sooooo light and relatively short. It seems more than fine just camera mounted.
Kirill
Aug 22, 2011 16:12 |  #13
There is a very nice solution to that http://dslrcontroller.​com/about.php (external link)
You can use Motorola Xoom with USB cable or some Android phones can be the remote liveview screen
weeatmice
Aug 22, 2011 16:32 |  #14
wombatHorror wrote in post #12979968 (external link)
The ring can be useful for mounting flash brackets depending on the setup.
FS: UK: 1D Mark IV.
Twopixel.co.uk (external link) | 500px (external link) | flickr (external link) | Twitter (external link) | Pinterest (external link) |
paulmoceyhanton
Aug 22, 2011 20:14 |  #15
The 100 2.8 non IS is amazing and you would save %50. I rarely need IS for macro work.
3,651 views & 0 likes for this thread
Latest registered member is markngolf2
1000 guests, 293 members online
