i tried a different approach as suggested in my first attempt......not shooting directly (from above) down...i am asking for your help again...this is the only way i can learn is from you guys....i really appreciate you guys......should i have used the Circular Polarize Filter to darken the blue sky? As well as anything else you guys see i need to correct
my camera settings were.........T2i....Kit Lens..18-55mm.....TV..1/250....f11...ISO 100...FL 24mm
) I have said it before on this forum: get yourself a depth of field calculator on your mobile phone and have a tape measure in your backpack. That way you can comfortably check on the optimal settings for depth of field at the right aperture and necessary shuttespeed and lowest ISO possible!
