Thread started 23 Aug 2011 (Tuesday) 08:34
So now I'm "stuck" with a Tamron 17mm prime
XxDJCyberLoverxX
Gallery: 30 photos
Aug 23, 2011 08:34 |  #1
I set my Tammy 17-50 to 24mm (and used tape to secure the zoom ring) to see how it would look like to walk with a 35mm prime for when I buy my 5D in a couple of months.
It was all fun and dandy until I took the tape off and tried to zoom the lens back. BIG PROBLEM. Seeing that the lens extends when zooming, I guess I must've jammed it when putting it back in my bag countless times.
It is very hard to turn the zoom ring; perhaps even to the point of impossible without breaking something internally.
Has this ever happened to anyone? I know its user error and "maybe" the lower-end construction of the Tamron. I managed to set it back to 17mm, but now I only have a 17mm prime.
Can anyone offer some advice?
So a note of caution: if you have a zoom that extends while zooming, then becareful when you "set it" at a certain length.
Daniel
Sony a7 / Sony a7s / FE 24-70mm / FE 28mm F/2 / Samyang 135mm
Nebula 4000 Lite / Manfrotto 190cx
POTN Feedback / My Work! (external link)
nepali
Aug 23, 2011 12:44 |  #2
XxDJCyberLoverxX wrote in post #12983928 (external link)
Have you checked your zoom lock?
[Current Gears: Fuji X-T4, Fuji 35 f/2, GoPro HERO8, YN-560 III]
[Feedbacks: #1, #2]
BrickR
Joined Mar 2011
Aug 23, 2011 14:43 |  #3
What kind of tape did you use and how long did you leave it on??
I've used that trick several times on different lenses but never had any problems once I removed the gaffers tape.
My junk
The grass isn't greener on the other side, it's green where you water it.
pxchoi
Aug 23, 2011 14:52 |  #4
As long as there is no physical damage on the lens, you can probably make a warranty claim. I've never done this with my lens, so I couldn't really say.
Patrick Choi
Portfolio (external link) | Flickr (external link) | Facebook (external link)
EOS 7D | 580EX II | 10-22mm f3.5-f4.5 | 17-55mm f/2.8 IS |70-200mm f/2.8L IS II
For Sale: 17-55mm f/2.8 IS | 10-22mm f3.5-f4.5
RPCrowe
Joined Nov 2005
Aug 23, 2011 16:01 |  #5
BrickR wrote in post #12986052 (external link)
Gaffers tape is a specialized tape (looks like duct tape but it isn't) which doesn't leave residue on anything to which you attach it. It is expensive but worth the money for certain uses...
XxDJCyberLoverxX
Gallery: 30 photos
Aug 23, 2011 20:47 |  #6
nepali wrote in post #12985369 (external link)
Yea I have. I made sure its unlocked.
Could it be the kind of tape? I used good 'ol scotch tape at home. I left it on for the whole day as I walked around and snapped pictures.
I'll see if I can make a warranty claim. If not, then I'll just brave it and try to take it apart :cry:
Daniel
goldboughtrue
Aug 23, 2011 21:02 |  #7
Sounds like the glue from the tape made it stick. But after just one day it shouldn't be that hard to move it. If you can feel tape residue where the tape was, then that's your problem.
http://www.pbase.com/g​oldbough (external link)
5D II, Canon 100 macro, Canon 70-200 f/4L, Canon 24-105 L, Canon TS-E 45, Sigma Art 35mm f/1.4
BrickR
Joined Mar 2011
Aug 23, 2011 23:23 |  #8
goldboughtrue wrote in post #12988108 (external link)
That's exactly what it sounds like. In heat, that adhesive gets soft and will find its way down into crevices. It will make things feel gummy, or worse when it cools off. :cry: That's why I chose the gaffy stuff.
My junk
3,660 views & 0 likes for this thread, 6 members have posted to it.
1036 guests, 107 members online
