24mm f1.4 L or 35mm f1.4 L cho 7D ?
What is better ?
Many thanks
Wish_Star Senior Member 292 posts Joined Dec 2010 More info | Aug 24, 2011 09:00 | #1 24mm f1.4 L or 35mm f1.4 L cho 7D ?
sebr Goldmember 4,628 posts Likes: 9 Joined Jan 2007 Location: Sweden/France More info | Aug 24, 2011 09:28 | #2 Both are excellent lenses... so it depends more on what FL you prefer. If you are not sure, you can always test 24mm and 35mm on your 15-85. Sebastien
Daedalus34r Senior Member 477 posts Joined May 2010 More info | go with the sigma30 f/1.4. 95% of the lens for a fraction of the price. BODY :: EOS 7D, EOS 50D
bobbyz Cream of the Crop 20,506 posts Likes: 3479 Joined Nov 2007 Location: Bay Area, CA More info | Aug 24, 2011 10:05 | #4 Depends on what you shoot. If wider then 24L. If thinking about 35L I may go for sigma 30mm f1.4 isntead. Fuji XT-1, 18-55mm
yourdoinitwrong Goldmember 2,394 posts Joined Apr 2009 Location: Indiana More info | If you are going to be using it for portraits I would not recommend the 24L unless you are doing full body shots. Getting in too close will give you some perspective distortion. It happens with my 35L if I do a head-only shot. Both are fantastic lenses though depending on your intended use. The Sigma 30 is a less expensive alternative but is softer in the corners. I tested out both the Sigma 30 and the 35L and the corner softness combined with all the instances of focusing issues pushed me toward the 35L. 5D4 w/BG-E20, 24-105 f/4L, 70-200 f/2.8L IS II, 35 f/1.4L, 85 f/1.8, 100 f/2.8L IS Macro, Sigma 50 f/1.4
sonnyc Cream of the Crop 5,175 posts Likes: 36 Joined Jun 2005 Location: san jose More info | Aug 24, 2011 11:00 | #6 |
Aug 24, 2011 23:02 | #7 24mm f1.4 L !!!
Aug 24, 2011 23:06 | #8 yourdoinitwrong wrote in post #12990862 If you are going to be using it for portraits I would not recommend the 24L unless you are doing full body shots. Getting in too close will give you some perspective distortion. It happens with my 35L if I do a head-only shot. Both are fantastic lenses though depending on your intended use. The Sigma 30 is a less expensive alternative but is softer in the corners. I tested out both the Sigma 30 and the 35L and the corner softness combined with all the instances of focusing issues pushed me toward the 35L. @yourdoinitwrong
cassidyphuey Senior Member 379 posts Joined Aug 2010 More info | Aug 24, 2011 23:10 | #9 Go for the Sigma version and spend the extra money on other stuff, such as more flashes, memory cards, etc.
x_tan Cream of the Crop More info | Aug 25, 2011 00:07 | #10 4x4rock wrote in post #12991023 I shot with both and own the 35L The 35L is a damn fine lens, but expensive The 24L II is a damn fine lens too, but more expensive. Pick your poison ![]() I picked 24L over 35L as 24L is a bit wider on crop Canon 5D3 + Zoom (EF 17-40L, 24-105L & 28-300L, 100-400L II) & Prime (24L II, 85L II, 100L, 135L & 200 f/2.8L II; Zeiss 1,4/35)
LostInInaka Senior Member 500 posts Joined Jul 2008 Location: Takizawa, Iwate, Japan More info | Aug 25, 2011 00:20 | #11 cassidyphuey wrote in post #12995291 Go for the Sigma version and spend the extra money on other stuff, such as more flashes, memory cards, etc. For a crop, this is excellent advice! If you plan on going FF soon, 24L II! 5DmkIII | Rokinon 35mm f/1.4 | Canon 16-35mm f/2.8L mk II | Canon 24mm f/1.4L mk II | Canon TS-E 24mm f/3.5L mk II | Canon EF 24-70mm f/2.8L | Canon 70-200 f/2.8L IS mk II | + Misc
newworld666 Goldmember 2,306 posts Likes: 20 Joined Jan 2009 Location: on earth More info |
Marc
yourdoinitwrong Goldmember 2,394 posts Joined Apr 2009 Location: Indiana More info | Aug 25, 2011 08:41 | #13 No, it can happen on either crop or FF. You will see this with a wide-angle lens when you are close to your subject. If you use your 15-85 to take a head shot of someone at 35mm and them move back and take the shot again at 85mm with the same framing you will see the difference. The subject's nose (or other features) in the center of the frame may look slightly bigger in the 35mm shot. This is why the 50mm or 85mm lenses are used frequently for portraits, they flatten the shot more than wider angle lens which results in a more pleasing photo. 5D4 w/BG-E20, 24-105 f/4L, 70-200 f/2.8L IS II, 35 f/1.4L, 85 f/1.8, 100 f/2.8L IS Macro, Sigma 50 f/1.4
bpark42 Senior Member 307 posts Joined Jul 2009 More info | Aug 25, 2011 09:21 | #14 yourdoinitwrong wrote in post #12996779 No, it can happen on either crop or FF. You will see this with a wide-angle lens when you are close to your subject. If you use your 15-85 to take a head shot of someone at 35mm and them move back and take the shot again at 85mm with the same framing you will see the difference. The subject's nose (or other features) in the center of the frame may look slightly bigger in the 35mm shot. This is why the 50mm or 85mm lenses are used frequently for portraits, they flatten the shot more than wider angle lens which results in a more pleasing photo. This is all true of course, but it is worth noting that perspective distortion will effectively be lessened for the same lens (focal length) with the same framing on APS-C vs. FF due to the fact that the camera-to-subject distance will necessarily be farther than it would on FF.
Aug 25, 2011 21:07 | #15 yourdoinitwrong wrote in post #12996779 No, it can happen on either crop or FF. You will see this with a wide-angle lens when you are close to your subject. If you use your 15-85 to take a head shot of someone at 35mm and them move back and take the shot again at 85mm with the same framing you will see the difference. The subject's nose (or other features) in the center of the frame may look slightly bigger in the 35mm shot. This is why the 50mm or 85mm lenses are used frequently for portraits, they flatten the shot more than wider angle lens which results in a more pleasing photo. Yes ! but 24L f1.4 for low light at home (for party im house) better than 35L ?
| Latest registered member is IoDaLi Photography 1820 guests, 118 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
