Thread started 24 Aug 2011 (Wednesday) 09:28
1Ds Mark II and Bulb Mode Problem
aroundlsu
Aug 24, 2011 09:28 |  #1
I am shooting timelapse sequences with my 1Ds Mark II and the TC80N3 controller. My exposures vary from 15 seconds to 1 minute in length. I have noticed that a 15 second exposure takes 15 seconds to write to my memory card. A 1 minute exposure takes an entire minute to write my memory card. A normal exposure writes quickly.
The problem with this is the buffer fills up quickly and won't take any photos until it finishes the long write.
What's up with this?
Teddy Smith, SOC
IATSE Local 600 Cinematographer
Jim_T
Joined Nov 2003
Aug 24, 2011 10:01 |  #2
It sounds like you have noise reduction turned on... (See page 129 in your user manual).
After your main shot, the camera will take a dark frame exposure of the same length with the shutter closed.. The noise in the dark frame is used to mask out the noise in the shot you just took. If you turn off noise reduction, then the delay should stop.
JonK
Joined Feb 2004
Aug 24, 2011 10:07 |  #3
Yep - Jim_T hit it on the head. Turn off noise reduction in camera.
7NE | 7D | 5DII | 16-35/2.8L II | 24/1.4L II | TS-E 24/3.5L II | 50/1.4 | 85/1.2L II | 100/2.8L IS | 70-200/2.8L IS II | 400/5.6L | PIXMA Pro 9500 Mark II
check my blog:
www.jonkensy.com (external link)
aroundlsu
Aug 24, 2011 10:45 |  #4
You guys were exactly right. Thanks so much!
Teddy Smith, SOC
1,232 views & 0 likes for this thread
Latest registered member is grannysclutter
786 guests, 190 members online
