I've searcher for about 1/2 hour for the answer, with no luck, so here it is:
I have the Lee filter holder, 4" x 4" CPL, and 4" x 4" 0.9 ND filter. If I use both filters at the same time, which one should be placed closest to the lens?
Alex_c70 Member 181 posts Joined Jul 2007 Location: Raleigh, NC More info | Aug 24, 2011 12:00 | #1 I've searcher for about 1/2 hour for the answer, with no luck, so here it is:
MartynAnstis Junior Member 29 posts Joined Apr 2011 Location: North Lincs, UK More info | Aug 24, 2011 12:10 | #2 I am pretty sure I read somewhere the CPL should be furthest away in the holder and the ND closest. Martyn
Aug 24, 2011 12:23 | #3 Martyn Anstis wrote in post #12991386 I am pretty sure I read somewhere the CPL should be furthest away in the holder and the ND closest. That's what I seem to recall, also. Hoping someone can confirm this.
Nobody knows?
sulli.gibson Member 82 posts Joined Jan 2011 Location: Chicago, IL More info | Aug 24, 2011 16:47 | #5 I can confirm that you should put the CPL in front of any other filters you're using. Also, definitely calculate exposures yourself, nd filters mess up your cameras meter readings as the densities of the filters get higher and higher. Basically use a chart (or do the math) for the best results. Sulli Gibson
SteveJa Goldmember 2,137 posts Likes: 23 Joined Dec 2008 Location: Nebraska More info | Aug 24, 2011 16:59 | #6 sulli.gibson wrote in post #12993060 I can confirm that you should put the CPL in front of any other filters you're using. Also, definitely calculate exposures yourself, nd filters mess up your cameras meter readings as the densities of the filters get higher and higher. Basically use a chart (or do the math) for the best results. so you are saying that the CPL should be furthest away from the lens?
lancebroad Senior Member 396 posts Likes: 1 Joined Jun 2009 Location: Brisbane, AU More info | Aug 24, 2011 17:02 | #7 Cokin in their filter holder that I own place the CPL closest to the lens and then you start stacking from there. Canon 6D | Canon 7D | Canon 5D mkII | 14L MK II | 24-70L | 70-200 f/2.8L | 100-400L | 400L f/2.8 | Zenitor 15mm | 580EX II |
sulli.gibson Member 82 posts Joined Jan 2011 Location: Chicago, IL More info | Aug 24, 2011 17:14 | #8 SteveJa wrote in post #12993099 so you are saying that the CPL should be furthest away from the lens? only if you're using the spots in front of it...basically, you want the light to be polarized before it goes through other filters for best results. if you're only using the polarizer, put it in the first slot. if youre using an nd grad, put that in the first slot, then the cpl in the 2nd. would you notice a difference? probably not, but thats what LEE recommends, and it can't hurt. Sulli Gibson
Aug 24, 2011 17:16 | #9 sulli.gibson wrote in post #12993060 I can confirm that you should put the CPL in front of any other filters you're using. Also, definitely calculate exposures yourself, nd filters mess up your cameras meter readings as the densities of the filters get higher and higher. Basically use a chart (or do the math) for the best results. Thanks Sulli! Do you think a 3 stop (0.9) ND will interfere with the cameras meter readings? Do you think it's best to get a base meter reading with no filters, then 'do the math' after filters are added (as opposed to letting the camera meter do its thing)?
sulli.gibson Member 82 posts Joined Jan 2011 Location: Chicago, IL More info | Aug 24, 2011 17:29 | #10 it definitely sounds like it's affecting your meter. getting a base meter reading is more important with 10 stop filters (esp. since you can't really see through them and they REALLY mess with the meter haha). in your case i'd probably put all the needed filters in place then use live view exposure simulation or just over expose by however many stops needed (AKA don't follow your meter too closely, you'll get a feel for it) and then look at the final histogram and make adjustments from there. in the end you want to overexpose as much as possible without clipping any highlights. Sulli Gibson
cagenuts Senior Member 860 posts Likes: 1 Joined Mar 2011 Location: Johannesburg, South Africa More info | Aug 25, 2011 04:06 | #11 sulli.gibson wrote in post #12993201 if youre using an nd grad, put that in the first slot, then the cpl in the 2nd. would you notice a difference? probably not, but thats what LEE recommends The big question is, which is the 1st slot and which is the 2nd slot? ...Ask me anything, I'm an ultracrepidarian.
LostInInaka Senior Member 500 posts Joined Jul 2008 Location: Takizawa, Iwate, Japan More info | Aug 25, 2011 05:23 | #12 ahhh Live view can help so much in cases like these...usually 5DmkIII | Rokinon 35mm f/1.4 | Canon 16-35mm f/2.8L mk II | Canon 24mm f/1.4L mk II | Canon TS-E 24mm f/3.5L mk II | Canon EF 24-70mm f/2.8L | Canon 70-200 f/2.8L IS mk II | + Misc
cagenuts Senior Member 860 posts Likes: 1 Joined Mar 2011 Location: Johannesburg, South Africa More info | Aug 25, 2011 05:46 | #13 LostInInaka wrote in post #12996155 and I believe its CPL at the outermost because it makes it easier to adjust Now Premier-Ink The P-type system consists of three main parts: an adapter ring which screws onto the front of your lens; a filter holder which slides onto the adapter ring; and one or more filters which slide into the filter holder. Round filters (eg. polariser, starburst) slide/rotate into the nearest slot from the lens, while normal 84mm square filters fit into the larger slot(s) in the holder. Seems to conflict with what you are saying although I agree with you as it make more sense to have the polariser changing the light first. Heck, maybe it doesn't make a difference. ...Ask me anything, I'm an ultracrepidarian.
argyle Cream of the Crop 8,187 posts Likes: 24 Joined Apr 2007 Location: DFW, Texas More info | The filter order doesn't matter...I've shot with the polarizer in front, and at the back...no difference whatsoever. About the only filter that MUST be mounted closest to the lens is the Lee Big Stopper (due to the sealing gaskets on the backside of the filter). Its not as complicated as folks are making it out to be. cagenuts wrote in post #12996036 The big question is, which is the 1st slot and which is the 2nd slot? Is this from the camera's perspective or the subject's? Typically, the first slot is the slot that's closest to the lens... "Fat, drunk and stupid is no way to go through life, son". - Dean Wormer
cagenuts Senior Member 860 posts Likes: 1 Joined Mar 2011 Location: Johannesburg, South Africa More info | Aug 25, 2011 06:37 | #15 Thanks man! ...Ask me anything, I'm an ultracrepidarian.
| Latest registered member is Frankie Frankenberry 1043 guests, 116 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
