I read about these awhile ago, I don't currently have any sort of NAS setup at all. Seems like a cheap enough solution its worth a try.
EBay link:
http://www.ebay.com …0.m2000036#ht_3570wt_1189![]()
bentlax33 Senior Member 430 posts Joined Jul 2010 More info | Aug 24, 2011 14:42 | #1 I read about these awhile ago, I don't currently have any sort of NAS setup at all. Seems like a cheap enough solution its worth a try.
sportmode Senior Member 549 posts Likes: 1 Joined Nov 2010 More info | Aug 25, 2011 00:36 | #2 bentlax33 wrote in post #12992326 I read about these awhile ago, I don't currently have any sort of NAS setup at all. Seems like a cheap enough solution its worth a try. EBay link: http://www.ebay.com …0.m2000036#ht_3570wt_1189 Make sure this one isn't affected by the recall 5D Mark III, 6D, EOS-M 22mm f/2 | 24-70mm f/2.8L II | 50mm f1.4 | 100L | 70-200mm f/2.8L IS II | Rokinon 8mm Fisheye
Aug 25, 2011 10:10 | #3 It's not that is a different model. This is the wifi model.
openingshok Member 60 posts Joined Jul 2011 Location: Paola, KS More info | Aug 25, 2011 10:14 | #4 I have one. It works pretty well. Very slow initially because it creates thumbnails and catalolgs metadata, so depending on how many media files you have don't expect it to work well for a couple weeks. It took mine a month to sort through thousands of pictures and 400 Gig of video files. Once that was done it runs pretty smooth. Brian
| Latest registered member is zachary24 1390 guests, 121 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
