Thread started 27 Aug 2011 (Saturday) 01:05
HELP WHAT IS THIS! T_T
Vixen89
Aug 27, 2011 01:05 |  #1
HELPP!! I can't get this to go away. T_T
I had a off camera flash 430 EX II sitting next to me fired up at the ceiling and I fired at 500 shutter speed @ 1.4.....this has been the second time I've seen this, I first encountered this 1 week ago but it went away and now it's back! I was using a Yongnuo RF-602 Trigger and Receiver...I noticed that when I used the on camera flash everything was fine. :S
IMAGE: http://i7.photobucket.com/albums/y266/RockinVixen89/asdfasdfasdf-1.jpg
I'm actively lazy!! :D | Gear List | photovxn.com (under construction)external link
Canonswhitelensesrule
Aug 27, 2011 01:15 |  #2
It looks as if your shutter speed (1/500 sec) is too fast. (Faster than the camera's max flash sync speed which is usually 1/200th-1/250th sec). It appears as if the shutter is closing before the flash can expose the entire photograph.
That would be my guess.
Photographers do it in 1/1,000th of a second...but the memory lasts forever! ;)
"It's only cheating if you get caught!" - Al Bundy
People who THINK they know it all really annoy those of us who DO!
theextremist04
Aug 27, 2011 01:17 |  #3
Yeah, you're exceeding your max sync speed. Or your shutter is dying, one of the two.
-Michael
Gear - Flickr (external link) - Website (external link) - Facebook (external link)
Vixen89
Aug 27, 2011 01:19 |  #4
I just read this thread: https://photography-on-the.net …/showthread.php​?t=1084032
..I tried again at 1/250 and it works ..user error stupidity me..all over again. I didn't know it couldn't keep up ..:S
ohata0
Aug 27, 2011 07:38 |  #5
when I need to use higher shutter speeds, I set it (430 EX II) up to use high speed sync. Although you can use higher shutter speeds, it lessens the power considerably (longer distances probably wouldn't work well if you use high speed sync) so keep that in mind if you use it.
Not sure if that would work correctly w/ the flash off camera though. I can setup the 430 EX II to high speed sync, but since I don't have another flash or cable like you have, the camera doesn't let me set a higher shutter speed. Attaching the flash to the camera lets me use higher shutter speeds in high speed sync.
1,434 views & 0 likes for this thread, 4 members have posted to it.
1044 guests, 110 members online
