Thread started 30 Aug 2011 (Tuesday) 08:31
any explain why benro tripods....
whu-1
Joined Aug 2011
Aug 30, 2011 08:31 |  #1
hi look fo a travel tripod , there no shops round here to go look :oops:
benro seam to fit the bill , looking for a short fold lenght , around the $350 mark
looking at these 4 model
BENRO Classic C2580F
BENRO Versatile C2980F
BENRO A0691TB00 Transfunctional Travel Angel
BENRO A1691TB0 Transfunctional Travel Angel
got 3 quetion
1. can any one explain what a "centre colum 0-180° Vertical/360° Horizontal" is ?
2. why only 1 year Warranty ? this the quality that bad and they dont stand behind there produce ?
3. ill probuble flip a coin :D or go with the BENRO Versatile C2980F as i can just get it in a back pack , can any one recomend a better tripod or at least in the same ball park as i cant find any reviews .
cheers and sorry just another witch tripod quetion and yes i googled and seached help
cheers for any help
:lol:
Mark-B
Aug 30, 2011 08:55 |  #2
You are looking at aluminum and carbon fiber. You are looking at the 0,1, and 2 series, which will all have different maximum heights, minimum heights, and weights. You are looking at models that support anywhere from 13 pounds to 24 pounds. You are looking at regular tripods and one with a center column made for low to the ground or macro work. Seems like you have no idea what you want.
Might as well save some money and get this one: http://www.amazon.com/​gp/product/B0027VSQ60 (external link)
This vendor must be clearing out their stock, because this particular model has been listed for $150 less than anywhere else for over a week.
Mark-B
msbphoto.comexternal link
whu-1
Joined Aug 2011
Aug 30, 2011 10:07 |  #3
im looking for a tripod that is
1. 1.7 kg or less
2. under 500mm or 20 inch ( 530 at a push if i like the othere points of the tripod )
3. max load of 8 kg to 12 kgs ( 6 kg at a push if i like the other points of the tripod )
4. flip locks a bonus
5. c/f or alu dose not matter .........as long as price is right around $350
6. max / min hights a trade off .............i realy like the 055cxpro3 but know its to long to fit in a bag hence will get left in doors ..........no use to any one.....
the new travel angles are 17.1 inch long thats why i looked at the other 2 .
how im doing ?
themadman
Aug 30, 2011 11:04 |  #4
whu-1 wrote in post #13023898 (external link)
Not sure if you know... every single Canon camera and lens only has a 1 year warranty... It just cuts costs.
Will | WilliamLiuPhotography.​com (external link) | Gear List and Feedback | CPS Member | Have you Pre-Ordered Your 3Dx Yet? | HorusBennu Discussion | In honor of Uncle Steve, thanks for everything! 10-5-2011
Joe ­ Ravenstein
Aug 30, 2011 11:42 as a reply to  @ themadman's post |  #5
Generally speaking if a component is going to fail it happens in the 1st year or even earlier so a year warranty is quite adequate for most gear.
Canon 60D,18-55mm,55-250mm,50mm compact macro, AF ext tubes. Sigma 8-16mm uwa, 18-250mm, 85mm F1.4, 150-500mm
whu-1
Joined Aug 2011
Aug 31, 2011 09:10 |  #6
hi there , canon warrenty ummmmm not starting that one but in most parts of the world its a guide , falls underthe heading of " fit for use " shore thats bean covered many times ......
going to fail in the frist year ........ some things yes , things like tripods ummmmmmmmm put it this way my job is fixing things , most things stress over time ..........cracks take time , burrs get bigger , sleave wear , nuts strip etc .
Oben “Oben understands that the stability and long-term performance of your gear is paramount, and it stands behind its tripods with a five-year warranty”
Gizto “extra 5 year period above and beyond the standard period imposed by the law in the country where the product”
Manfrotto “Standard 2 Year Limited Warranty and eligible for a Free 8 Year Limited Conventional Warranty Extension”
Vanguard “ 2 years to life time “
just wondered why 1 year if its a sound product ..........
whu-1
Joined Aug 2011
Aug 31, 2011 09:12 |  #7
And the main quetion
1. can any one explain what a "centre colum 0-180° Vertical/360° Horizontal" is on benro ?
i live a fair distance from the camrea store :-)
Joe ­ Ravenstein
Aug 31, 2011 09:36 |  #8
it means you can tilt the center column from straight up to right angles from the tripod head, such as when shooting macro images of flowers as one example.
whu-1
Joined Aug 2011
Aug 31, 2011 09:49 |  #9
cheers joe , thanks for the help , thought i might mean all the angle between 0 and 180 , cheers for the clarifcation ...............:-)
2,017 views & 0 likes for this thread
Latest registered member is StevePB
789 guests, 211 members online
