Hi
can a Flipside 300 carry a manfrotto 055pro with head 498RC2 or MA 410 ?
or is too weak and not enough resistent for this tripod?
in the spec there is a light tripod...
mantra Goldmember 1,617 posts Joined Nov 2006 Location: Italy, Rome More info | Aug 31, 2011 00:57 | #1 Hi canon 5d markII,24L & 24ts , 35L ,17-40L,24-70L,70-200 2.8ISL,50 1.4,85 1.4 , canon eos 3 ,eos 5 ,t90 , ae program and some very sweet fd lenses
ShaneW Senior Member 839 posts Likes: 2 Joined Jan 2008 Location: Traverse City, Michigan More info | Aug 31, 2011 07:48 | #2 I think it would be tough to carry a larger tripod on a small backpack! I have an OLD set of 055pro size legs and it carries fine on my NatureTrecker AW bag but is way too top heavy on my Rover AWII. The 055 line is not a "light" tripod! Shane W
Aug 31, 2011 09:13 | #3 Shane W wrote in post #13029266 I think it would be tough to carry a larger tripod on a small backpack! I have an OLD set of 055pro size legs and it carries fine on my NatureTrecker AW bag but is way too top heavy on my Rover AWII. The 055 line is not a "light" tripod! thanks a lot canon 5d markII,24L & 24ts , 35L ,17-40L,24-70L,70-200 2.8ISL,50 1.4,85 1.4 , canon eos 3 ,eos 5 ,t90 , ae program and some very sweet fd lenses
Mjkxxl Member 199 posts Joined Dec 2010 More info | Sep 01, 2011 10:37 | #4 The Fastpack 300 will hold the 055pro for sure. -Mark
richielee14 Member 83 posts Likes: 4 Joined Jul 2011 Location: London, UK More info | Sep 01, 2011 16:16 | #5 Im using a Flipside 200, holding a 190XProb with 498RC2. It's a bit top heavy so I velcro the top handle of the bag to the ballhead, just stability. 6D Gripped - 14mm T3.1 - 35 f2.0 - 50 f1.8 - 24-105 f4 IS L - 70-200 f4 L
antonlindstrom Member 138 posts Joined Aug 2011 More info | Sep 01, 2011 16:23 | #6 I use a 055xprob with amedium head.. And I must say, sticking it to my new flipside400aw doesnt feel as right as I thought it would.. As mentioned it sways a bit, a tighter fit would be desired.
Mjkxxl Member 199 posts Joined Dec 2010 More info | Sep 01, 2011 16:27 | #7 antonlindstrom wrote in post #13037234 I use a 055xprob with amedium head.. And I must say, sticking it to my new flipside400aw doesnt feel as right as I thought it would.. As mentioned it sways a bit, a tighter fit would be desired. With that said, the tripod is kind of heavy, and not all of the leg tips will fit in the small pull out pouch. This might be the problem, however I think LowePro could have come up with a better sollution to a bagseries this pricey. I believe the pouch on the back that holds the tripod legs is designed in such a manner that only 2/3 of the legs fit inside of the pouch, as the rest remain outside. -Mark
antonlindstrom Member 138 posts Joined Aug 2011 More info | Sep 01, 2011 16:31 | #8 Yeah, it might be meant to hold only 2 leg tips.. Haven't hade alot of time to do testing, but this was one of the first things I noticed on the bag, and it is kind of bad not having another strap or something.
TheRan Goldmember 1,555 posts Likes: 2 Joined Jan 2010 Location: Hertford, England More info | Sep 01, 2011 17:49 | #9 My Giottos is around the same size as either the 190XPROB or 055XPROB, I forget which, and although my Flipside 300 will hold it it's not the most brilliant feeling in the world. The strap is about half way up the legs and they stick out a lot, I can't count the number of people I was close to knocking out with it when turning around.
richielee14 Member 83 posts Likes: 4 Joined Jul 2011 Location: London, UK More info | Sep 02, 2011 05:32 | #10 Here is how I secure my tripod. Doesn't move an inch when secured with the strap up top. I attached it to the handle up the top for hanging the bag, I presume that the handle is designed to hold up the bag, so it the weight of the tripod should be ok. 6D Gripped - 14mm T3.1 - 35 f2.0 - 50 f1.8 - 24-105 f4 IS L - 70-200 f4 L
| Latest registered member is semonsters 1053 guests, 103 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
