Thread started 31 Aug 2011 (Wednesday) 18:44
photograph film negatives
chantu
Aug 31, 2011 18:44 |  #1
Hi,
I have a bunch of negatives from the pre-digital days, and I was wondering if it's possible to use my camera to photograph the color negative, and then "reverse" everything in post (I have LR3, CS5) to make a "positive". Thanks.
DC ­ Fan
Aug 31, 2011 19:05 |  #2
A film scanner (external link) is the correct tool for the job.
tim
Light Bringer
Aug 31, 2011 19:15 |  #3
You can outsource it to a company that will do it for you, which is way easier. Google will find the companies.
ameerat42
Aug 31, 2011 19:23 |  #4
1. Yes.
2. Give it a try.
Am.
chantu
Aug 31, 2011 19:26 |  #5
ameerat42 wrote in post #13032588 (external link)
1. Yes.
2. Give it a try.
Am.
How can I do the "negative" to "positive" conversion.
ameerat42
Aug 31, 2011 19:33 |  #6
I can only tell you for Photoshop...
Start with Image-Adjustments-Invert
Am.
tonylong
...winded
Gallery: 60 photos
Aug 31, 2011 19:51 |  #7
1. Yes.
2. Give it a try.
Am.
I'm curious -- have you done this, photograph actual negatives? If so what method did you employ?
Tony
Joe ­ Ravenstein
Aug 31, 2011 20:06 |  #8
The Canon Canoscan 9000 comes with both 35 mm slide and 35mm film strips and 120(6x6) film carriers. A necessity for predigital camera gear, assuming one does such "work"
Canon 60D,18-55mm,55-250mm,50mm compact macro, AF ext tubes. Sigma 8-16mm uwa, 18-250mm, 85mm F1.4, 150-500mm
crn3371
Aug 31, 2011 21:31 |  #9
Scanner.
tonylong
...winded
Gallery: 60 photos
Aug 31, 2011 22:04 |  #10
crn3371 wrote in post #13033179 (external link)
Scanner.
Yes, it definitely can be done with a scanner, and you can get a dedicated film/transparency scanner it's the best way for a consumer to go --and, in fact, some scanning software has a built-in negative converter, to get you off to a good start.
But, I was curious about the question of the OP, and especially about the "Yes!" response -- I'd like to know if anyone has actually succeeded in photographing negatives, and if so how! Otherwise the OP is best just to go the scanning route.
Tony
TheBurningCrown
Aug 31, 2011 22:06 |  #11
chantu wrote in post #13032600 (external link)
Use the curves tool and invert the points. In other words: / should look like \.
tonylong wrote in post #13033324 (external link)
I've done it. See here: https://photography-on-the.net …/showthread.php​?t=1081676.
-Dave
Gear List & Feedback
Hypnotizedd
Joined Nov 2010
Aug 31, 2011 22:08 as a reply to  @ TheBurningCrown's post |  #12
http://www.youtube.com​/watch?v=AgOTk4ApEYs (external link)
tonylong
...winded
Gallery: 60 photos
Aug 31, 2011 22:18 |  #13
TheBurningCrown wrote in post #13033334 (external link)
I've done it. See here: https://photography-on-the.net …showthread.php?​t=1081676.
OK, so what was your method in actually photographing them? It looks like maybe you held them up against a light background and just took a pic? My concerns would be with curve in the negatives but it looks like yours came out pretty well. I can imagine someone setting up a light table for this type of thing.
Tony
tonylong
...winded
Gallery: 60 photos
Aug 31, 2011 22:32 |  #14
Well, as goofy as DigitalRevTv is, I'd say that YouTube video linked to by Hypnotizedd had some pretty nifty DIY stuff on this! I'd say that if you watch it you will have enough ideas to be well on your way!
Tony
TheBurningCrown
Aug 31, 2011 22:35 |  #15
tonylong wrote in post #13033416 (external link)
If you read the post I do go into detail on that.
Curvature of the negative could be an issue, though mine are old enough to be pretty flat. Regardless, sandwiching them in acrylic is always an option.
-Dave
2,238 views & 0 likes for this thread, 10 members have posted to it.
1397 guests, 119 members online
