Thread started 31 Aug 2011 (Wednesday) 19:16
Can this photo be fixed in Photoshop?
texshooter
Aug 31, 2011 19:16 |  #1
Shot with 17mm lens. Looks tunneled. Can it be fixed in PS? How?
FlyingPhotog
Cream of the "Prop"
Aug 31, 2011 19:18 |  #2
You can fix the perspective but you'll end up having to pull the two nearest vertical lines completely out of the frame to do so...
Jay
chauncey
Aug 31, 2011 19:31 as a reply to  @ FlyingPhotog's post |  #3
Probably is an interesting shot with the correct lens and perspective.
tonylong
...winded
Gallery: 60 photos
Aug 31, 2011 19:33 |  #4
Yeah, I was gonna say -- Photoshop does have a Lens Correction tool that you can use to "fix" the vertical perspective but you lose "chunks" of the image when doing so -- basically in this shot your bottom corners woud be "anchored" as you pull back on the upper corners, waay back in this case. So, draw an imaginary line from your bottom corners "truly vertically up" and imagine that all on the sides of those lines will be lost!
Now with some of the fancy tools in Photoshop you may be able to do some "construction work" on things, but it would be quite a task to make it work!
Tony
Titus213
Aug 31, 2011 22:11 |  #5
I tried pushing the bottom together and it works somewhat. Lots of work involved in getting it to look good though.
Dave
Perspiring photographer.
903 views & 0 likes for this thread, 5 members have posted to it.
1032 guests, 109 members online
