Coming through the merchant lines is this Off-Camera Cord, with several useful added features. Pricing is unknown at present.
The basic kit (PF801 – Canon) comes with a 0.3/1ft, 2m/6ft or 4m/12ft cable. Extra Pixel cables come in 2, 3, 5, 8 and 10m lengths. Also available are extra VS-801flash shoes.(The Nikon version is VM802.)
Mount the VS801 on the camera and plug the cable into the right (C) socket. Connect the other end to the VM801, mount the Speedlite, and turn on. Switch on C, and move the TTL switch to C also. Confirm that it all works by calling up the Flash Control Menus on your camera to check settings.
There are 3 line switches and 1 TTL switch. A or C can be switched to TTL mode.
A On/Off TTL on/Manual
B On/Off Manual/Manual
C On/Off Manual/TTL on
This provides a mixed ETTL/Manual sync. Having only one set, we have been unable to test whether a second cable can be piggy-backed to extend the Manual lines.
A standard 6-wire straight-through Ethernet can be used. I have a 10m one for use as Syl Arena describes. A 0.5m one suits an on-camera flash bracket.
With the ability to connect by cable to a Master at that distance means that the Componor is a worthwhile backup system to the Pixel King wireless system. In fact, is adds in A:B ratios, as well as full FCM control of the lighting, so both systems work in exactly the same way. I’m in.
