Thread started 02 Sep 2011 (Friday) 20:20
Benro A-2691+ B-1 short center column
Hermeto
Sep 02, 2011 20:20 |  #1
I have Benro A-2691 tripod with B-1 head and I am trying to find the right short center column for it.
Adorama, B&H and Vistek offer pretty much the same product, recommended for Series 2 Benro tripods:
http://www.adorama.com​/BEELA2.html (external link)
http://www.bhphotovide​o.com …_Low_Aluminum_C​enter.html (external link)
http://www.vistek.ca …ize-2-aluminum/Specs.aspx (external link)
However, all of them have 24mm column diameter and I am positive (measured) that my long center column has 28mm diameter!
Benro site confirms that:
http://www.benro.cn …Id=1&id=131&Pro​ductId=361 (external link)
Vistek has similar product which is 28mm but it looks like not fully assembled:
http://www.vistek.ca …e-column-wat08-plate.aspx (external link)
So, which one to order?
Before calling tech support, I'd like to know if any of you guys have the experience with short center column for Benro Series 2 tripods.
Could someone actually measure the diameter of both long and short columns?
SteveJa
Sep 02, 2011 20:34 |  #2
this might help some, with part number and what it fits.
http://www.ebay.com …ain_0&hash=item​4841debeb5 (external link)
Zenfolio (external link)
FineArtAmerica (external link)
LostInInaka
Sep 02, 2011 21:01 |  #3
SteveJa wrote in post #13043351 (external link)
I have the same tripod, just the carbon version (C2691) which has the exact same specs, just made with a different material and ordered the C(arbon) version of the short column listed above...
got it in last week and it fits perfectly, however the head of the short column is not removable as a whole (thus it can't be used on the monopod) if that is of any concern...but you can swap the mounting screw by undoing the top nut
Also that seller is great with communication and shipping...I buy all by benro stuff through them.
5DmkIII | Rokinon 35mm f/1.4 | Canon 16-35mm f/2.8L mk II | Canon 24mm f/1.4L mk II | Canon TS-E 24mm f/3.5L mk II | Canon EF 24-70mm f/2.8L | Canon 70-200 f/2.8L IS mk II | + Misc
klr.b
Sep 02, 2011 22:00 |  #4
They're all probably going off of the wrong specs. It should be 28mm. If you're worried, you could probably call them and ask them to measure.
LostInInaka wrote in post #13043437 (external link)
I think this older version (external link) would have worked. They used to sell these as a center column only, and you had to switch over your mounting base.
gordon
Gear and Feedback
Hermeto
Sep 03, 2011 03:59 |  #5
Thank you gentlemen!
I guess I'll call either Adorama or B&H on Monday and ask them to measure the damn thing.
Vistek would be the most convenient for me, but they don't have it in stock.
If it appears to be 24mm, I'll have to order it form eBay.
Once again, thank you all!
HelenOster
That's me!
Sep 04, 2011 07:43 |  #6
Hermeto wrote in post #13044507 (external link)
Better to email, as we need to get a message across to the warehouse manager to arrange this.
If you email me directly with the exact model info, (including the SKU number) to Helen @adorama.com, I'll ensure it gets done.
4,045 views & 0 likes for this thread, 5 members have posted to it.
521 guests, 153 members online
