Thread started 03 Sep 2011 (Saturday) 15:18
Lasso Tool - Any way to "Undo" the last click?
Radtech1
Everlasting Gobstopper
Joined Jun 2003
Sep 03, 2011 15:18 |  #1
ARRGH! -
I am working on a composite that requires a good deal of Lasso Tool selections. Is there any way to undo the last click?
As I am selecting away, the "delete" key will undo clicks (anchor points) as I go - so far, so good. The problem is that sometimes I will be following a curve, and be click, click, clicking as I set down anchor points then all of the sudden, PS thinks I have "double clicked" and it prematurely completes the selection - putting in a straight selection line from there back to the start point. This usually cuts my selection in half or worse, depending on how complex it is.
Anyways, when this happens, the "delete" key no longer works the way it should, by deleting the previous anchor point, no, instead it deletes the whole selection along the wrong lines.
Is there any way to undo that final "completing" click and go back to a "selection in progress"? The history is useless because it does not store individual anchor points.
Alternatively, is there any way to disable the "auto complete" of selections?
CS-3 on Vista 32.
Thanks.
Rad
Be humble, for you are made of the earth. Be noble, for you are made of the stars.
Damo77
Sep 03, 2011 15:20 |  #2
If you've got a half-completed selection, just hold down Shift to begin adding to it.
Damien
Website (external link) | Facebook (external link)
D ­ Thompson
Sep 03, 2011 15:26 |  #3
Use the pen tool instead of the lasso tool. Once you have the path laid out, right click and make selection. Much more flexible than the polygonal lasso tool.
Dennis
Canon 5D Mk III 5D 20D
I have not yet begun to procrastinate!
Damo77
Sep 03, 2011 15:29 |  #4
Dennis is right, in part. The lasso tool should never be used for this kind of work. Use it to make a very rough selection, then turn that selection into a mask, then use your brush to fine-tune the mask.
Of course, there are lots of ways to select something, and it all depends on the image.
Damien
Radtech1
Joined Jun 2003
Sep 03, 2011 15:30 |  #5
Damo77 wrote in post #13046373 (external link)
What do you do when it "completes" like this, where the selection now consists of three fingertips of various sizes and two triangles of background?
Any help with this one. (Because this is EXACTLY what prompted me to post.)
Thanks,
Rad
D ­ Thompson
Sep 03, 2011 15:39 |  #6
Damo77 wrote in post #13046408 (external link)
Hey, I'll take being part right!;) Agree, several ways to do selections and probably the only thing the lasso is good for is rough selections.
Radtech1 wrote in post #13046410 (external link)
Thanks,
Rad
I hate to say it, but I think you're sol and will probably have to start over. :(
Dennis
Radtech1
Joined Jun 2003
Sep 03, 2011 15:43 |  #7
D Thompson wrote in post #13046397 (external link)
I tried the Pen Tool, and can't make heads or tails of it. Instead of making a line, it creates angles and loops that remind me of a spirograph!
I also tried the Free-Form Pen Tool which does allow me follow a desired shape, but when I complete it, it "rounds it off" unacceptably. And even then, once I do get an area selected, I am unable to delete the selection as with the lasso tool. In this case, the delete key simply removes the selected area?!?
I don't even want to ask "What am I doing wrong with this tool?" because I am sure the answer is everything.
Damo77
Sep 03, 2011 15:44 |  #8
Rad, may I say something without causing offense? I've seen you around here for a long time, and you've always struck me as a very skilled operator. So I'm GOBSMACKED that you're using the lasso tool like this. In Photoshop terms, it's a kindergarten method.
Damien
Damo77
Sep 03, 2011 15:50 |  #9
Radtech1 wrote in post #13046369 (external link)
http://damiensymonds.b​logspot.com …vs-copy-then-extract.html (external link)
Damien
Radtech1
Joined Jun 2003
Sep 03, 2011 15:53 |  #10
Damo77 wrote in post #13046455 (external link)
Absolutely no offense taken.
There was an old Star Trek Next Generation where the whole crew disappeared one at a time leaving just Crusher - who was aware of the disappearances, and Picard who was not. At one point, in exasperation, she asks him, "How can the two of us run an entire Starship without a crew?" He simply shrugged and said, "We never needed one before."
And likewise, I never needed any other tool before. Lasso has always served my purposes - albeit, with annoyances, but served them none-the-less.
So I guess, without having to climb a new learning curve in the middle of a project, does anyone know how to turn off the "autocomplete"?
Rad
D ­ Thompson
Sep 03, 2011 15:54 |  #11
Radtech1 wrote in post #13046449 (external link)
The pen tool can be very, very frustrating at first especially, but it is pretty powerful. Just click to lay down an anchor point, when you click and drag is when you get the spirograph. However, the click and drag can make some nice curves. The good thing is you can use shf, alt, & ctl to modify another anchor point. I never use the Free-Form pen tool. Once you have your selection and want to delete it use press and hold {ctrl} and then press d. That will delete the selection only.
Hope this helps a little.
Dennis
D ­ Thompson
Sep 03, 2011 16:20 |  #12
Radtech1 wrote in post #13046487 (external link)
Rad
Not off the top of my head. Only thing I can think of would be maybe change your mouse double click speed setting to see if that helps.
Dennis
Radtech1
Joined Jun 2003
Sep 03, 2011 16:39 |  #13
D Thompson wrote in post #13046569 (external link)
Hmmmmm....
Never thought of going outside of PS. I think you just solved the (immediate) problem. Going forward, I will try to take a look at that pen tool.
Rad
Damo77
Sep 03, 2011 16:41 |  #14
Y'know how I said Dennis was "part" right?
Well, the part he was wrong about was the pen tool. It's a stupid tool
Stick to masking.
Damien
Radtech1
Joined Jun 2003
Sep 03, 2011 16:51 |  #15
Damo77 wrote in post #13046636 (external link)
Stick to masking.
Aaaaaaaaaaaaand I'll take a look at masking, too.
17,593 views & 0 likes for this thread, 9 members have posted to it.
1048 guests, 105 members online
