What do I need to fire a Quantum 5DR remotely in manual mode from a 5D II? What would I need to fire it remotely in ETTL mode?
elguapo Senior Member 348 posts Joined Apr 2007 Location: Texas More info | Sep 04, 2011 23:49 | #1 What do I need to fire a Quantum 5DR remotely in manual mode from a 5D II? What would I need to fire it remotely in ETTL mode? Love without truth is hypocrisy; Truth without love is brutality.
PhotographersWorldWide Senior Member 395 posts Joined Mar 2008 Location: UK More info | Sep 05, 2011 02:22 | #2 The 5DR can be triggered by any radio trigger using a PC cable sync, or you can use the plug-in Quantum FW7Q radio receiver on the 5DR and trigger it with a camera based transmitter - FW9T.
Sep 05, 2011 12:23 | #3 I tried firing one with NPT-04 flash trigger and had no luck. The light on the NPT-04 transmitter and receiver were going off, and they work on other flashes, so I know the NPT-04 is working. I also know there was no problem with the Quantum flash. Love without truth is hypocrisy; Truth without love is brutality.
PhotographersWorldWide Senior Member 395 posts Joined Mar 2008 Location: UK More info | Sep 05, 2011 12:46 | #4 Did you try switching the HH plug around, sometimes the polarity can be wrong due either to cable, receiver or whatever ? Also check your shutterspeed is within normal X-sync range for the 5DII. I don't know whether this might affect the sync from the NPT-04, but it might.
Sep 05, 2011 12:54 | #5 Well, I take back what I wrote above. The T5DR comes with a cable that has prongs on one end and a plug that fits in to a hole on the side of the NPT-04 receiver on the other end. The NPT-04 transmitter does fire the T5DR when I use this arrangement. Love without truth is hypocrisy; Truth without love is brutality.
PhotographersWorldWide Senior Member 395 posts Joined Mar 2008 Location: UK More info | Sep 05, 2011 13:03 | #6 You can plug an earphone in that socket above the HH socket and hear the audio ready beep without annoying anybody, It's an earphone jack, not a sync socket. If your T5DR is new there should be an earphone in the box too.
| Latest registered member is johntmyers418 991 guests, 108 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
