Thread started 05 Sep 2011 (Monday) 03:00
Best prime wide angle lens, wider than 24.
fitshaced
Joined Jul 2011
Sep 05, 2011 03:00 |  #1
I'm looking for a wide angle prime to give me a bit more width over my 24-105. i already have a tokina 11-16 but, as wider lenses push the subject further away, I'd prefer another option between 16 and 24. A prime would be preferable. I'll probably consider selling the tokina if could find a better wide option.
http://www.flickr.com/​photos/picsbykev/ (external link)
Kolor-Pikker
Sep 05, 2011 03:18 |  #2
If money is no object, then 17mm TS-E :lol: It's certainly the best Canon lens in this FL range by a long shot, if not one of the best WA's in general.
However, I see that you have the Tokina 11-16mm, isn't that an APS-C only lens? If that is so and you have a 1.6x crop camera, then it's going to be a significantly cheaper endeavor to simply get a full-frame camera than trying to get a good wide angle.
Your 24-105mm will effectively go down in field of view to 15mm as you see it on your current camera.
5DmkII | 24-70 f/2.8L II | Pentax 645Z | 55/2.8 SDM | 120/4 Macro | 150/2.8 IF
I acquired an expensive camera so I can hang out in forums, annoy wedding photographers during formals and look down on P&S users... all the while telling people it's the photographer, not the camera.
fitshaced
Joined Jul 2011
Sep 05, 2011 03:48 |  #3
Kolor-Pikker wrote in post #13052621 (external link)
Dammit, you're right :p
mmgoodies
Joined Jul 2011
Sep 05, 2011 12:44 |  #4
so true
plasticmotif
Sep 05, 2011 13:01 |  #5
Zeiss 21, TSE 24, TSE 17, Olympus 21/2 or /3.5, Leica 19, Samyang 14, Canon 14, Leica 15, ZE 18.
Pretty much in that order.
Mac P.
My Zenfolio (external link) My Photo Blog (external link) My Equipment
https://photography-on-the.net …p?p=14172975#po​st14172975
noisejammer
Sep 05, 2011 16:45 |  #6
I have the 17 TS-E and the ZE 21/2.8.... Sadly, the Zeiss lens has hardly had anything to do since I got the TS-E. It is a truly wonderful lens indeed.
Several cameras and more glass than I will admit to.
TuanTime
Sep 05, 2011 19:16 as a reply to  @ noisejammer's post |  #7
Or you could wait for the Samyang 24mm too.
fitshaced
Joined Jul 2011
Sep 05, 2011 19:30 |  #8
24 isnt wide enough on a crop.
I think the 5D III will be my next purchase. In 2013 most likely.
haroldwilson
Sep 05, 2011 19:36 |  #9
10-22?
fitshaced
Joined Jul 2011
Sep 05, 2011 19:37 |  #10
That's not a prime :p
Hogloff
Joined Apr 2003
Sep 05, 2011 20:06 |  #11
noisejammer wrote in post #13055195 (external link)
Filters are a pain in the ass with the 17 TSE. I shoot 99% of my landscapes with at least one filter so the 21 ZE is much better in this aspect.
plasticmotif
Sep 05, 2011 21:10 |  #12
Hogloff wrote in post #13056137 (external link)
the 24 TSE is better than the 17 too.
again see my last post.
Mac P.
Kolor-Pikker
Sep 05, 2011 23:32 |  #13
You can technically use filters on the 17, it's just very expensive; filter holder/slide filters/etc. And yes, the 24 is a better lens, but once you reach the high-end you'll be splitting hairs in quality. Also tilt-shift; never under estimate it's power, get a whole landscape in focus at f/8 from a couple feet to infinity..
In any case, now that I think of it, the "EF-S 15-55 f/2.8 IS" doesn't sound like a bad idea. It's not going to help push the OP over into full-frame land, but it does only cost about $1100, which is rather inexpensive compared to all the strictly-WA options mentioned and from what I've seen it's a very highly-rated lens. It also stops short of the 11-16, so there may even be reason to keep both.
It's really up to the OP now, go full-frame and have it easy with WA options, or get a second standard zoom that can go wide enough.
amfoto1
Sep 06, 2011 00:12 |  #14
I like the Canon 20/2.8 a lot. Since you are using an 11-16, I'm assuming you are shooting with a cropper. If that's the case, if you were to get the 20mm, I'd keep the 11-16 too.
But why are you stuck on a prime? If using a crop, the Canon 10-22 is excellent. Tokina 12-24 is good too. The first images I've seen from the new Sigma 10-20/3.5 also look darned good. And there's a new Sigma 12-24 II full frame lens coming soon, too.
nikesupremedunk
Sep 06, 2011 00:15 |  #15
looking for something in the 16-24 range? tokina makes that too! get the 16-28 lol
| Andrew | 5D Mark II | EOS-M | Canon 17-40mm f 4 L | Canon 35mm f 1.4 L | Canon 100mm f 2.8 L Macro | Canon 70-200mm f 4 L IS | Canon EF-M 22mm f 2.0 | Speedlite 430EX II|
2,153 views & 0 likes for this thread, 10 members have posted to it.
999 guests, 110 members online
