Hi, will the following 5D2 functions affect raw images, or only jpg images?
- Peripheral illumination correction
- Auto lighting optimizer
- Highlight tone priority
Thanks in advance!
mrmarks Senior Member 822 posts Likes: 11 Joined Jan 2010 More info | Sep 05, 2011 12:03 | #1 Hi, will the following 5D2 functions affect raw images, or only jpg images?
windpig Chopped liver More info | Sep 05, 2011 13:26 | #2 Highlight Tone Priority because it effects exposure. Would you like to buy a vowel?
tonylong ...winded More info | Sep 05, 2011 15:25 | #3 Hmm, well, let's back up a little bit... Tony
windpig Chopped liver More info | Sep 05, 2011 17:55 | #4 RAW converter aside, here is an explanation, it is what I've been led to believe over the years; Would you like to buy a vowel?
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Sep 05, 2011 18:28 | #5 I suspect HTP does but not the rest. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
tonylong ...winded More info | Sep 05, 2011 18:37 | #6 windpig wrote in post #13055493 RAW converter aside, here is an explanation, it is what I've been led to believe over the years; http://www.cambridgeincolour.com …/thread2052.htm#post17586 Heh! Since it's a forum thread it reminds me of the discussions we've had here since this camera "feature" (HTP) came out -- and, most of the "knowledgable" people who posted came to the same conclusions that I posted above, but of course since Canon And Adobe have not as far as I know disclosed the "inner workings" of all this all such things are "educated guesses" and so you'll see some variations even amongst "experts". Tony
windpig Chopped liver More info | Sep 05, 2011 19:33 | #7 Hi Tony Would you like to buy a vowel?
tonylong ...winded More info | Sep 05, 2011 20:11 | #8 Well, yes that the camera exposes at the lower ISO, so in that sense it underexposes shadows and midtones. That is the light the sensor collects and the ISO amplifier applies "standard ISO amplification to and so the result is the Raw data, the same as you would get with the lower ISO setting. What does not affect the Raw data is the "rest" of HTP, what makes HTP "different" from either "native" ISO setting -- it does not apply the tonal curve that boosts the shadows and midtones while retaining the highlights. Tony
Shooting Goldmember 1,552 posts Likes: 3 Joined Jan 2008 More info | I know this is an old thread but I got a question that I cannot find but I'm sure it is out there somewhere. Does HTP and ALO work if shooring in manual in jpeg format?
tonylong ...winded More info | Jan 15, 2012 13:44 | #10 If you turn HTP and/or ALO on, then sure they affect the jpegs -- that's what they are for. It doesn't matter what exposure mode you use (Manual, Av, Tv, P) -- those settings work on the image after it is taken, prior to saving the jpeg. Tony
Shooting Goldmember 1,552 posts Likes: 3 Joined Jan 2008 More info | Ok thank you..but when using a speedlight, does it affect the image or over ride what those two functions do because it is lighting them up? Or do they process the image even after it is taken with flash and then adjust?
tonylong ...winded More info | Jan 15, 2012 18:13 | #12 Hmm, well I can't answer that -- I never turn HTP on and I don't have a camera with ALO...if you have a camera with both functions, try it out and let us know! Tony
| Latest registered member is semonsters 1470 guests, 131 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
