Thread started 06 Sep 2011 (Tuesday) 10:35
17-55 not sharp at all with filter on
eaglefan
Sep 06, 2011 10:35 |  #1
I've noticed that my 17-55 consistently takes photos that are not sharp at all, almost blurry, with a high quality B+W filter attached. The photos are much sharper when I take the filter off. I'd like to be able to use a filter to protect the lens from little hands (I often am shooting little kids), but the photos are unacceptable when using a filter.
Has anyone else experienced this? I can post examples later.
5D Mark IV (2) l RP l 70-200mm f/2.8L IS II l Canon 24-105 l Canon 85L 1.4
MattTorresPhoto.com (external link)
zaphod911
Sep 06, 2011 11:28 |  #2
Odd. I use a Hoya HMC UV(c) filter and there is no visible degradation whatsoever. The 17-55 is one lens I always keep a filter mounted to minimize dust infiltration. Two years, lots of use, and no visible dust.
I have used poor filters which result in shots with more glare and contrast loss but have never experienced a blurry photo because of a filter.
Have you tried swapping with another filter, or conversely, used that specific filter on another lens?
3Rotor
Gallery: 72 photos
Sep 06, 2011 11:31 |  #3
You may have gotten a counterfeit filter.
I've been using a Hoya Super HMC UV(0).
Every filter added in front of glass will effect IQ. The IQ degradation was negligible for my taste.
Instagram (external link)
www.jessemak.com (external link)
gjl711
"spouting off stupid things"
Sep 06, 2011 11:37 |  #4
Can you post a pic with filter on and the same settings filter off? I have noticed a similar thing with my 100-400 and have narrowed down to some weird interaction between a filter and the IS. I did a bit more experimenting and even a UV filter does this.
https://photography-on-the.net …hp?p=10424981&p​ostcount=6
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
ps_n_dslr
Sep 06, 2011 12:14 |  #5
I had a similar experience (but on my 18-55 IS) that I nearly lost a stop with filter on then without.
From what I learnt, it has to do with cheapo filters or as someone pointed out knock-offs.
Try to ensure it is the case with a genuine one (may be a friend's or rental) to see that there's nothing wrong with your lens. Good Luck
eaglefan
Sep 06, 2011 12:33 |  #6
gjl711 wrote in post #13059067 (external link)
I can post some pics tonight. That is very interesting regarding IS. I'll try turning it off to see if that makes a difference. As for the filter, I purchased it directly from Amazon.com, not a 3rd party through Amazon. I guess it could still be a counterfeit, though.
OneJZsupra
Sep 06, 2011 15:04 |  #7
I use to run filters on all of my lenses but I (Hoya S-HMC filters) and I find that If I can get away with not having a filter then I'll keep it in the bag for the better IQ and to help flaring. I think you best bet would be to just run with out the filter and use you lens hood. I just use my judgement for what i'm shooting and where, If theres sand or I'm by the ocean then I'll use a filter. Other things like if i'm going somewhere with tons of people that could bump into my lens or if your shooting sporting events then you might want to consider it but in more cases then not having the lens hood should work fine for it.
Gear List | Feed Back | My Site (external link)
YN RF-603 O-ring solution
1,868 views & 0 likes for this thread, 6 members have posted to it.
670 guests, 119 members online
