I know this is a dumb question to most of you, but what is full frame referring to? And what are the advantages?
Eng27DCFD Member 239 posts Joined May 2007 Location: Maryland More info | Sep 06, 2011 20:58 | #1 I know this is a dumb question to most of you, but what is full frame referring to? And what are the advantages?
Sep 06, 2011 21:01 | #2 The sensor is the same size as a frame on a roll of 35mm film. Most digital cameras have sensors smaller than that, sometimes a lot smaller. In general, larger sensors have better dynamic range, lower noise, and narrower DOF than smaller sensors of the same technology generation.
Sep 06, 2011 21:02 | #3 No dumb questions here. It's the size of the image sensor, full frame is 36×24 mm which is the same as a 35mm film frame.
windpig Chopped liver More info | Sep 06, 2011 21:05 | #4 Advantages; Would you like to buy a vowel?
Jumpcut Member 182 posts Joined Oct 2008 Location: Australia More info | Sep 06, 2011 21:27 | #5 How can someone who has 204 posts and been here for almost 5 years not know what full frame is? There is a new thread every day on the topic. Darren
10megapixel "I'm a little slow" 3,872 posts Likes: 5 Joined Oct 2008 Location: Surrounded by Corn and Rednecks in Indiana More info | Sep 06, 2011 21:32 | #6 Jumpcut wrote in post #13061615 How can someone who has 204 posts and been here for almost 5 years not know what full frame is? There is a new thread every day on the topic. Maybe the OP has been making use of other parts of the forum that don't discuss DSLR's, or possibly didn't have any interest in Full Frame until recently. Heck, I didn't give a rats ass about full frame until two weeks ago myself
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | Sep 06, 2011 21:59 | #7 When camera manufacturers started designing digital SLRs (DSLRs), they decided that the DSLR bodies should be about the same physical size and configuration as their 35 mm film SLRs. The early DSLRs were made with sensors that were significantly smaller than the film frame in 35 mm film SLRs (which was 36 mm wide by 24 mm tall). The format (size of the sensors) of the early DSLRs is the same "APS-C" format that's used today for most of Canon's DSLRs. The 35 mm film format was dubbed as "full-frame" when digital cameras were made with 36 mm by 24 mm sensors. Skip Douglas
chiggah Member 35 posts Joined Mar 2011 More info | Sep 06, 2011 22:15 | #8 Why is 35mm the standard and nothing larger than that ?
RTPVid Goldmember 3,365 posts Likes: 3 Joined Aug 2010 Location: MN More info | Sep 06, 2011 22:22 | #9 chiggah wrote in post #13061875 Why is 35mm the standard and nothing larger than that ? Cost. You can buy digital cameras with sensors the size of what was called "medium format" in film, but they are quite expensive. The sensor is probably the most expensive part of a DSLR, and the larger they are, the more expensive they are. Tom
cassidyphuey Senior Member 379 posts Joined Aug 2010 More info | Sep 06, 2011 22:23 | #10 chiggah wrote in post #13061875 Why is 35mm the standard and nothing larger than that ? There is.
Sep 07, 2011 00:09 | #11 chiggah wrote in post #13061875 Why is 35mm the standard and nothing larger than that ? There are various sizes, for years I shot 2 1/4 x 2 1/4 film.
kcbrown Cream of the Crop 5,384 posts Likes: 2 Joined Mar 2007 Location: Silicon Valley More info | Sep 07, 2011 01:10 | #12 I'm not convinced of this. If I'm not mistaken, dynamic range is the result of the signal to noise ratio of the sensor at base ISO. That isn't a function of sensor area, it's a function of well size per area and the read noise per area, which is a function of the sensor construction itself, not the sensor size. Better high ISO performance Generally yes, because of the additional light gathering capability in the frame. However, note that for this, too, you have to use the shallower depth of field capability of the sensor. Shallower depth of field Yep. Disadvantages; Lower high speed frame rate No. That's not a function of the sensor size, at least for the sensor sizes we're talking about. Canon is perfectly capable of building a 10 FPS full frame camera if it wants to. It has in the past (the EOS 3 is capable of doing 10 FPS with the high-speed film drive grip). Cost No question about this. Smaller sensors have better yields and are less expensive to construct. "There are some things that money can't buy, but they aren't Ls and aren't worth having" -- Shooter-boy
tonylong ...winded More info | Sep 07, 2011 02:51 | #13 Eng27DCFD wrote in post #13061479 I know this is a dumb question to most of you, but what is full frame referring to? And what are the advantages? chiggah wrote in post #13061875 Why is 35mm the standard and nothing larger than that ? Actually all these terms are relative. in the "big picture" of photography they are meaningless, because over the decades there have been many fil formats -- in fact, our "standard" print sizes go back a long ways and in no way reflect something historically considered "full frame". In 35 mm (135 film So, you can't "blame" the term "full frame" on DSLR stuff, it goes back to when 35mm film was the standard movie film size and compared to smaller film was called "full frame". And 35mm still film was actually "taken" from movie film, so the idea went along: when 35mm film became the "standard" for our SLR and then DSLR systems, the name tag went along with it! Tony
BigAl007 Cream of the Crop 8,119 posts Gallery: 556 photos Best ofs: 1 Likes: 1682 Joined Dec 2010 Location: Repps cum Bastwick, Gt Yarmouth, Norfolk, UK. More info | Sep 07, 2011 03:30 | #14 Nice post Tony, although a couple of points for complete accuracy. The first Canon camera that used the EF-s mount was the 300D aka original Rebel. The first of the xx line to have it was the 20D.
tonylong ...winded More info | Sep 07, 2011 06:15 | #15 BigAl007 wrote in post #13062934 Nice post Tony, although a couple of points for complete accuracy. The first Canon camera that used the EF-s mount was the 300D aka original Rebel. The first of the xx line to have it was the 20D. The other bit that I found difficult to follow was your attempt to explain the smaller image circle of crop only lenses and the effect that has on field of view, but that is difficult to put simply for all to understand as the numerous threads we see here on POTN shows. Alan Ah, well, Al ,thanks for clarifying things! Lke I said, I don't have all the details down, but I hope I did an OK job of "painting the big picture"! Tony
| Latest registered member is ANebinger 1314 guests, 176 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
