ckale1 wrote in post #13069761
If you don't have a PC running 32 bit XP with a firewire connection, find a friend who does. Install the EOS Utility and connect your Camera. You will have to install the drivers for the camera also. Go to the personal settings in the utility and check on everything. Once you install this to the camera, you can make changes at the camera level.
Just a clarification:
Custom Functions are set through the camera menu,
Personal Functions have to be set through EOS Utility,
Name and 'phone number to show in the EXIF have to be set through EOS Utility.
Sometimes later version of EOS Utility will not 'talk' to the camera despite having the correct WIA Driver and Firewire drivers installed on a 32bit OS - in this case try a version of EOS Utility that is as old as the camera, or try using an older 32bit OS (like Win XP instead of Vista) - this seems to depend on the Firewire card/drivers...............
