jffielde wrote in post #13070530
I bought the 17-40mm when I first started out, and then later "upgraded" to the 16-35mm II and shot it for about a year before selling it and re-buying the 17-40mm. They are generally indistinguishable in terms of IQ (most reviews seem to find the 17-40 to be
better for landscaping), so it's a pretty easy call if you don't need the 2.8. Take a look at SLR Gear comparisons, Digital Picture Lens Comparisons, and Luminous Landscapes comparisons of both lenses, which are generally similar to my own experience).
EXACTLY the same situation here. Assuming the OP meant the 16-35 II that is. I found that the IQ of both of Canons UWA zooms is not really perfect either way you go. Add to that the fact that if youre going to be using it for landscape shots, youre going to be shooting at f/8 or smaller to get that DOF, so what goo is the f/2.8 of the 16-35 II going to do for you? Even if youre a wedding photographer or something and you want wide shots in a dimmly lit church or something f/2.8 still wont give you the DOF you might need to get the whole venue in focus. So youll still be shooting at least f/4 or smaller. PLUS that 82mm filter size is a killer! I was happy to sell off the second B+W KSM CPL filter and UV filter I had at 82mm just to support that 16-35 II. Now with 17-40L Im back to my good ole 77mm that all my other L lenses use!
So, long story short, let me save you the time, money and stress and dont bother with 16-35 II and get the 17-40L.
OR, if you MUST have wider, and money is no object: well then, high roller
get the Canon EF 14mm f/2.8L! Now THERE is an amazing wide angle lens! 14mm with no distortion!? Amazing!
