Hi, does anyone have an idea if the 504HD head can be fitted into the 055CXPRO tripod? Any adapters or modifications needed? I'm trying to avoid spending on another tripod if I get this head. Thanks
mrmarks Senior Member 822 posts Likes: 11 Joined Jan 2010 More info | Sep 09, 2011 06:33 | #1 Hi, does anyone have an idea if the 504HD head can be fitted into the 055CXPRO tripod? Any adapters or modifications needed? I'm trying to avoid spending on another tripod if I get this head. Thanks
Headshotzx Goldmember 4,488 posts Likes: 141 Joined Dec 2007 Location: Singapore More info | Sep 09, 2011 06:41 | #2 |
ben_r_ -POTN's Three legged Support- 15,894 posts Likes: 13 Joined Nov 2007 Location: Sacramento, CA More info | Sep 09, 2011 12:14 | #3 The 504HD is a 75mm bowl head. It CAN be used with a flat mount, non-bowl tripod like the 055CXPRO with a high hat like this: LINK [Gear List | Flickr
Sep 09, 2011 12:19 | #4 Thanks Ben! Good to know I have this option
ben_r_ -POTN's Three legged Support- 15,894 posts Likes: 13 Joined Nov 2007 Location: Sacramento, CA More info | Sep 09, 2011 12:25 | #5 mrmarks wrote in post #13076043 Thanks Ben! Good to know I have this option Yep! I actually own that high hat and head. I bought the high hat to use the head on a slider (or anything else for that matter). Then I use the head on a Gitzo 3541LS with a 75mm bowl adapter to hold the 504HD. Its a decent head and def the cheapest I would recommend going, but Ill probably be selling it soon to upgrade to a Sachtler. [Gear List | Flickr
Headshotzx Goldmember 4,488 posts Likes: 141 Joined Dec 2007 Location: Singapore More info | Sep 09, 2011 12:57 | #6 |
ben_r_ -POTN's Three legged Support- 15,894 posts Likes: 13 Joined Nov 2007 Location: Sacramento, CA More info | Sep 09, 2011 13:29 | #7 Headshotzx wrote in post #13076222 Whoa Ben, since when did you have the 3 series? I always thought you were the GT1541t guy ![]() I have both now. The 1541T/Q3T AND 3541LS/Q20 combo now [Gear List | Flickr
Sep 09, 2011 17:43 | #8 ben_r_ wrote in post #13076069 Yep! I actually own that high hat and head. I bought the high hat to use the head on a slider (or anything else for that matter). Then I use the head on a Gitzo 3541LS with a 75mm bowl adapter to hold the 504HD. Its a decent head and def the cheapest I would recommend going, but Ill probably be selling it soon to upgrade to a Sachtler. Ben, I'm assuming that the short bottom shaft at the bottom of the head has to be removed/unscrewed out before fitting to the bowl adapter? Which Sachtler head are you looking at, FSB8?
ben_r_ -POTN's Three legged Support- 15,894 posts Likes: 13 Joined Nov 2007 Location: Sacramento, CA More info | Sep 09, 2011 22:09 | #9 mrmarks wrote in post #13077526 Ben, I'm assuming that the short bottom shaft at the bottom of the head has to be removed/unscrewed out before fitting to the bowl adapter? Which Sachtler head are you looking at, FSB8? Yes and yes. You just put the Gitzo 75mm bowl adapter in between the head and its screw rod and then tighten it down. Then you can keep that whold section together and remove it or insert it into the Gitzo 3541LS legs anytime you need it. I swap between that and the Gitzo baseplate with a Markins Q20 head on it depending on what I need the legs for. That way my 3 series does double duty. [Gear List | Flickr
| Latest registered member is semonsters 1470 guests, 131 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
