Thread started 12 Sep 2011 (Monday) 10:22
Auto iso: why does my speedlight choose ISO400 ?
boerewors
Joined Sep 2009
Sep 12, 2011 10:22 |  #1
If i set iso to auto and use a speedlight, it then always wants iso 400. Why is this? I assume it will allow the batteries to be saved, but when trying to ballance a subject with ambient, does it make any difference seeing that i have to stop down in order to expose for a sunny environment. In my particular case i had to choose f14 in order to expose a portrait of someone standing in direct sunlight and my flash was set to full power through an umbrella. The next shot was dialed to f10 but iso 100 and the flash still on full power, the exposure was exactly the same and seemed even better due to less noise.
Is this ISO thing for speedlights only intended for shady areas or something. Because if thats the case i can understand why is because you can use a lower flash power, but when going against the mid day sun does it make any difference?
Thanks for taking your time to read this. Any enlightment will be apreciated.
The most important piece of gear you own, resides in your head and its called your brain.
Mr.Beast
Joined Nov 2010
Sep 12, 2011 13:59 |  #2
The in camera meter is for ambient light exposure. It doesn't know how much flash is going to be in the picture. With ettl, when you press the shutter button, the flash fires a preflash, which then tells your camera how much flash to add.
5D classic - 1000d - 28/2.8 - 50/1.8 - 85/1.8 - Mamiya RB67
krb
Sep 12, 2011 14:09 |  #3
Like Mr. B. said, the varying the ISO adds to many variables for the camera to handle.
The real answer is that if you want to take control of the situation, such as when balancing with ambient, you really should just take control and skip the automated BS. If you want ISO 100 then set the camera to ISO 100.
-- Ken
Gear list
Curtis ­ N
Master Flasher
Sep 12, 2011 14:58 |  #4
Valid points, well-taken.
Still, wouldn't it be cool if the camera would adjust the ISO in the same manner as it adjusts the shutter speed in Av mode or adjusts the aperture in Tv mode?
Is that really too much to ask?
BrandonSi
Nevermind.. I'm silly.
Gallery: 62 photos
Joined Sep 2004
Sep 12, 2011 15:02 |  #5
Curtis N wrote in post #13091221 (external link)
The 5D Mark II has auto ISO, and I think some of the newer Rebels, as do some Nikon bodies... though I couldn't imagine ever using it.
[ www (external link)· flickr (external link)]
krb
Sep 12, 2011 15:04 |  #6
BrandonSi wrote in post #13091257 (external link)
If you read the rest of the thread, you'll see that we are discussing how that auto ISO works...
-- Ken
Gear list
BrandonSi
Gallery: 62 photos
Joined Sep 2004
Sep 12, 2011 15:05 |  #7
krb wrote in post #13091268 (external link)
This entire thread is just confusing, and hurts my head..
krb
Sep 12, 2011 15:05 |  #8
If you think it's bad as is, you should have tried it on the 40D. It basically just used ISO 400 no matter what.
-- Ken
Gear list
windpig
Chopped liver
Sep 12, 2011 17:08 |  #9
When learning flash, one needs to keep it simple. Adding Aut ISO to the equation is the last auto function I'd be adding.
Go ahead, spin the wheel.
boerewors
Joined Sep 2009
Sep 12, 2011 19:15 |  #10
Thanks. I thought as much. Seems like im going full manual everything for todays shoot :)
yogestee
Sep 12, 2011 20:48 |  #11
krb wrote in post #13090972 (external link)
Best advice on offer..
Jurgen
windpig
Chopped liver
Sep 12, 2011 22:22 |  #12
boerewors wrote in post #13092515 (external link)
ETTL can work wonders as long as you know it's limits.
v_lestat
Sep 12, 2011 23:33 |  #13
just curious what shutter speed were you seeing as a result?
and were you using m, tv or av modi am not surprised it was holding iso400, but also what sync speed to the flash were you using?
unless i misread... full daylight with a full speedlight blast seems pretty excessive.
but iso 400 should produce zero noise that is visible in any normal prints unless you are printing lifesize
Curtis ­ N
Master Flasher
Sep 12, 2011 23:55 |  #14
v_lestat wrote in post #13094196 (external link)
Not at all. In full daylight, a full power blast from the Speedlite is often necessary to compete with the sun and lift the shadow areas (depending on the distance). Since you're limited to X-sync shutter speed, you control exposure by using ISO 100 and stopping down the aperture.
Wilt
Sep 13, 2011 11:55 |  #15
Auto ISO does some very bizarre things without flash. https://photography-on-the.net …p?p=13029993&po​stcount=21 It is quite consistent in doing some oddball things with flash, too.
Even the newer models continue to do bizarre things with Auto ISO, even though they are better than the earlier, more flawed Auto ISO models.
10,200 views & 0 likes for this thread, 16 members have posted to it.
2380 guests, 102 members online
