Thread started 12 Sep 2011 (Monday) 14:33
Battery grip battery usage...
dan.k78
Sep 12, 2011 14:33 |  #1
Does anyone know how the camera uses a pair of batteries when in a battery grip? Do they drain equally or does the camera run through one of them and then jump to the next? I ask because the other day while out shooting, when I checked the battery life, it told me at one point that both batteries were at approximately 15%. When i got home, i took one battery out and it still read 15%, then I switched that battery out for the other one, it said it was at 94%. I'm confused. Anyone got any thoughts on this? Thanks.
Gear: 5DIII; 6D; Canon 16-35 f/4L; Canon 24-70II f/2.8L, Tamron 70-200mm f/2.8 VC; Sigma 35mm f/1.4A; Sigma 105mm f/2.8 Macro; Phottix Mitros+;580exii; Metz AF 50-1
yourdoinitwrong
Sep 12, 2011 18:15 |  #2
From what I understand it tries to equal them out, at least on my 7D. Usually I charge both at the same time but the few times I haven't it used the battery with the higher charge.
5D4 w/BG-E20, 24-105 f/4L, 70-200 f/2.8L IS II, 35 f/1.4L, 85 f/1.8, 100 f/2.8L IS Macro, Sigma 50 f/1.4
Full List
The ­ Ran
Sep 12, 2011 21:02 |  #3
It will drain them equally. The reason you get the same percentage whether it's with one or two batteries is because one is 15% out of 100% and two are 30% out of 200%, which is of course also 15% of 100%. Now this is all assuming you start off with two fully charged batteries, if you swap out one for another at 100% I assume it would give you a 58% total, and once the 15% battery is drained it would then carry on to run off just the one battery.
MadlyAlive
Sep 12, 2011 23:21 |  #4
I had thought it drained them equally, but for some odd reason the last few times I've pulled mine out of the grip to charge them, one of them was always showing fully charged.
5D Mark III Gripped ~ 7D Gripped ~ EF 70-200mm f/2.8L IS II USM ~ EF 24-70 f/2.8L USM ~ EF-S 10-22mm f/3.5-4.5 USM ~ EF 50mm f/1.8 II ~ 550EX ~ 600EX-RT
The ­ Ran
Sep 12, 2011 23:54 |  #5
Are you using the official Canon grip? I always thought it used them equally just like the third party ones, however I only have the Meike grip and its instructions to check so may be mistaken.
gtrag94
Joined Aug 2011
Sep 13, 2011 00:00 |  #6
That is weird, everything I've read about it is that it uses them simultaneously.
Fort Wayne, IN Portrait & Wedding Photographer
http://www.craigagapie​photography.com (external link)
http://www.facebook.co​m/CraigAgapiePhotograp​hy (external link)
MadlyAlive
Sep 13, 2011 00:12 |  #7
The Ran wrote in post #13094294 (external link)
All Canon, all the time...batteries too :)
yogestee
Sep 13, 2011 09:20 as a reply to  @ MadlyAlive's post |  #8
My Phottix grips on my 20D and 50D use the power out of the left hand (looking from the back) first and when drained automatically use the right hand battery.
Jurgen
dan.k78
Sep 13, 2011 09:25 |  #9
yogestee wrote in post #13095837 (external link)
Seems that is what my Opteka grip is doing as well.
Hermeto
Sep 13, 2011 09:39 |  #10
Long time ago I read an explanation by Canon's Chuck Westfall IRRC, about battery usage in Canon grips.
If voltage in two batteries is not equal, grip discharges battery with higher voltage first.
When voltages on both batteries become equal, discharging goes alternatively, one at the time.
I don't remember any more details, perhaps someone has more reliable source..
______________
Okay, here is one from the Similar Threads:
https://photography-on-the.net …hp?p=9281279&po​stcount=88
xhack
Sep 13, 2011 10:20 |  #11
Both my 5D and 20D grips (Canon) do this. With batteries bought at the same time and never mixed or swapped over between grips. Always drains LH battery first; the RH goes to the charger and full charge pops up in 30 seconds. I swap over the batteries in the grip after charge to equalise usage.
~ Wallace
2,050 views & 0 likes for this thread, 8 members have posted to it.
1062 guests, 104 members online
