ok so im going to try this.. cheap enough..
i also see 2 different types..
you can
1. buy an adapter that allows you to screw 2 lenses together... so 55-250 and 15-55????
2. buy an adapter that allows the one lens to be rotated and screwed into the body
does one work better than the other? ok so for $10 i can get both and most likely will.. just looking for what people have to say..
i see people doing the dual lens.. but not much on the one lens..
now i saw the pringle can trick.. that just seems weird.. i do have a mount i can cut the hole in.. give the kids the pringles to empty can... paint can.... put 18-55 lens into other end of can... viola...
so the 3rd one is a true DIY... but which out of the 3 should produce the better results knowing they are all a cheap way...
