Thread started 15 Sep 2011 (Thursday) 22:36
Uv filter test .....
whu-1
Joined Aug 2011
Sep 15, 2011 22:36 |  #1
Hi guys , im being a little think , can some one explain What is meant by Mean transmission of ultraviolet light , in the lenstip review of the hoya hd uv filter .
http://www.lenstip.com …ent_Hoya_HD_UV_​67_mm.html (external link)
Dose this score afect the image ?
Does the sense on the 60d have a ultraviolet filter any way ?
Cheers :)
RHChan84
Joined Apr 2011
Sep 15, 2011 23:26 |  #2
http://www.youtube.com …lRevCom#p/u/9/-e9TUIC-Dtk (external link)
Here is a better answer.
Canon (60D Gripped | 18-135mm f3.5-5.6 IS | 40mm f2.8 | 50mm f1.8 | 70-200 F4L IS| 430 EXII)
Tamron (17-50 f2.8 VC)
Feedback
Facebook (external link)
Wilt
Sep 15, 2011 23:49 |  #3
UV filter effectiveness rating is a meaningless thing to measure for digital cameras, as there is already a UV filter just in front of the sensor. It is the UV filter which you are actually dusting off with a blower or a special wipe, not the sensor surface!
whu-1
Joined Aug 2011
Sep 16, 2011 03:25 |  #4
Ok so i was right that the sensor has a uv filter built in :D
So if add in that score , it comes out at 93 percent for the hoya hd flitter .....
Still what does......
The absorption edge is a bit too close to near ultraviolet – it costs the filter 5 points in the appropriate category.
Mean ? :rolleyes:
And will this efect the image ?
hollis_f
Sep 16, 2011 05:21 |  #5
whu-1 wrote in post #13111983 (external link)
Mean ? :rolleyes:
It means that the filter will absorb a bit of visible light (violet) as well as UV. That will give a small colour cast to your images - but it's hardly going to be noticeable.
Frank Hollis - Retired mass spectroscopist
Give a man a fish and he'll eat for a day. Teach a man to fish and he'll complain about the withdrawal of his free fish entitlement.
Gear Website (external link)
crn3371
Sep 16, 2011 10:26 |  #6
What it all boils down to is this. If you're looking for a UV filter to protect your camera from UV rays, don't bother. The only real reason people use them any more is for physical protection, which itself is another can of worms.
MCAsan
Joined Jun 2010
Sep 16, 2011 11:34 as a reply to  @ crn3371's post |  #7
exactly. UV filters made sense in the film days...not really appropriate in the digital days.
whu-1
Joined Aug 2011
Sep 16, 2011 20:03 |  #8
The main point of the filter for me is protection, due to the way the filter screws on the impact is dispersed when dropped , protecting the lens body and front lens watch some of the digitalrev videos and this is borne out , but all so for use when paragliding hence alt and on hazy at sea cant hurt .
Hence looking at the hoya hd uv .
Looking for a filter with minimal impact.
"It means that the filter will absorb a bit of visible light (violet) as well as UV. That will give a small colour cast to your images - but it's hardly going to be noticeable."
thats what i thought but then they write this
Mean transmission of visible spectrum light 98.3% - Score: 9/10
seams a little odd to half one score and only reduce the othere by 1 if thats the case .
thanks for the reply hollis btw cheers :-)
Wilt
Sep 16, 2011 20:12 |  #9
whu-1 wrote in post #13115875 (external link)
I once had an Olympus zoom lens, one of the first high quality zooms to exist, way back decades ago. Back then, I too, was under the false guidance that a filter 'protected' a lens to impact damage. FALSE!!! I was in Germany, touring a castle. In tight quarters I turned to my right, causing the camera to swing away from my body and crash lens first into a stone wall. The filter was unscratched, the lens was unscratched, but the zoom mechanism was jammed so that the WA portion of the zoom range was not accessible...my 35-70mm zoom turned into a 45-70mm zoom, until it was sent to Olympus to undo the collision damage internally!
The ONLY 'protection' that any filter provides is a shield against wind blown sand or salt spray hitting the front element, or keeping the reaching slimey hands of toddlers from touching the front element. It MIGHT do some good in keeping a paint ball from striking the front element, by destroying the filter when struck. That is all. The rest of physical 'protection' is purely accidental and not assured!
SkipD
Joined Dec 2002
Sep 16, 2011 20:19 |  #10
The main point of the filter for me is protection, due to the way the filter screws on the impact is dispersed when dropped , protecting the lens body and front lens...
That is totally false. For any device to "disperse" (absorb) energy on impact, that device has to squash, bend, or break on impact.
Think about the water-filled or sand-filled barrier barrels you see on a highway in front of something that you wouldn't want to run into. The way they work is by squashing over time when they are hit, reducing the peak energy applied to the car.
A photographic filter simply has no way to absorb any significant amount energy and thus cannot possibly protect a lens on impact. The same forces will be applied to the innards of a lens whether there's a filter on it or not.
On the other hand, if there's a rigid lens hood mounted, there is a good possibility that the hood will bend or break up on impact, absorbing energy and potentially preventing damage to the lens.
Skip Douglas
Wilt
Sep 16, 2011 20:23 |  #11
SkipD wrote in post #13115920 (external link)
...or the rigid hood can serve as a longer lever arm, aiding in breaking the lens into two, as has been documented via a number of photographs of Canon lenses broken in half with the hood mounted, even the 'robust' L lenses!
whu-1
Joined Aug 2011
Sep 16, 2011 21:23 |  #12
"That is totally false. For any device to "disperse" (absorb) energy on impact"
"A photographic filter simply has no way to absorb any significant amount energy and thus cannot possibly protect a lens on impact"
ummmmm whats happerning in the digitalrev video then ?
www.youtube.com/watch?​v=cT6wBQR7iqE (external link)
energy going some were :-)
and the original quetion not bean answers .
any one know why ?
Jon
Joined Jun 2004
Sep 16, 2011 21:25 |  #13
Skip, you're oversimplifying here. If you've got a filter on and the lens hits on a corner, it'll be on a corner of the filter and the impact won't materially affect the threads on the lens. Whereas, if you weren't using a filter and the lens took the same fall, the lens will need to be repaired before you'll be able to use any filter again. I've got an old FD-mount 500 cat. that suffered exactly that damage and the screw-mount hood doesn't want to thread on any more.
Jon
Cocker Spaniels
SkipD
Joined Dec 2002
Sep 17, 2011 04:44 |  #14
Jon wrote in post #13116165 (external link)
While that's true, a filter ring with no glass in it would do the same thing. But if a hood were mounted you'd also be protecting the filter threads in most cases.
Obviously, there are cases like what Wilt mentioned above but for the typical bumps that a lens takes I would rather a hood take the hit than anything solid such as the lens itself or a filter attached to the lens.
Skip Douglas
Wilt
Sep 17, 2011 11:45 |  #15
Filters are primarily for optical changes to the light path.
Hoods are primarily for shielding the front optics from stray bright light sources (e.g. sun, artificial light source).
ANY other use of the two accessories is purely incidental to their primary purpose. In SOME cases, they afford a degree of 'protection', but in others they can CONTRIBUTE to damage of the lens or the optical characteristics of a photo!!! That is, the 'protection' is not absolute.
Buy and use the accessories for their primary purpose, not solely for their secondary characteristics.
2,438 views & 0 likes for this thread
Latest registered member is StevePB
730 guests, 232 members online
