Thread started 17 Sep 2011 (Saturday) 07:00
HELP - 16GB Ram issues with asus p8p67pro
tommmy.star
Sep 17, 2011 07:00 |  #1
Hi guys,
I have built my own Pc some time ago and since day one I had problems with it when I ran 16GB of ram. Things wouldn't install properly, CS5 and Lr would not start at times and I had constant errors when I ran sfc command. I've run numerous overnight memTests on Ram in different configurations( 4x4, 1x4, 2x4) and they are ok. I just know it's not a Ram issue. The system runs beautifully on 8GB. No problems whatsover. Then I read somewhere that if you want more than 8GB of ram on p8p67pro than you need to tweak some ram settings. I know that every mobo is different but I would appreciate if someone could help me with some more detailed list of what settings to change etc to make it all work. I have tried different forums but most of them allow you to post stuff if you're a seriuos OC and have replied like 100 times to other threads.
Looking forward to heraing from you.
Canon 5DIII |Canon 30mm f2 | Canon 85mm f1.2L |Canon 100mm f2.4L| Canon 70-200mm f2.8II L
London Wedding Photographer (external link)
My 500px.com (external link)
YP5 ­ Toronto
Sep 17, 2011 15:21 |  #2
ok...well if you say you have tested the ram (tried each module individually in each slot in various combinations) and its good then a few questions.
are the 4GB modules the same brand and model?
Do you know the specs, the timings and the reco'd max voltage?
If so, go into your MB bios then you should go in and manually set the speed and timings and voltage.
Also, what OS are you running? 32bit /64bit?
Canon 7D Gripped |Tokina 11-16 | Sigma 30mm F1.4 |Canon EF 24-70L | |Canon EF 70-200L F2.8IS MKI |Sigma 530DG | Giottos 9360 | Giottos MH-1301 | Giottos MH656 | Spyder2Pro | Kata 3IN1-20 | Kata Bumblebee UL-222
tommmy.star
Sep 17, 2011 16:24 |  #3
YP5 Toronto wrote in post #13119129 (external link)
Correct.
Yes - CRUCIAL DDR3 - 1333(Pc3 10600)
1.5V
This is the part where I need your help guys. What do I need to change and where.
Win 7 64 bit
YP5 ­ Toronto
Sep 18, 2011 14:19 |  #4
umm...little difficult for me to explain, moreover my ASUS board is different.
Look at this video outlining how to OVERCLOCK. Same thing. About 1/3 way through the video shows adjusting memory timings and voltage.
http://www.youtube.com​/watch?v=1MJUpBHIHrQ (external link)
Citizen_Insane
Sep 19, 2011 14:02 |  #5
You may need to lower your timings to run all 4 slots. I know that some boards have issues if you fill all the ram slots (stupid, I know).
A better place to ask this question is undoubtedly here: http://hardforum.com/ (external link)
Gear
tommmy.star
Sep 19, 2011 14:45 |  #6
Citizen_Insane wrote in post #13128259 (external link)
Thanks, for your reply, however I am afraid I need a little bit more specific answer than that. Lower Ram's timings to what? and where/under which tab in bios do I do that?
Citizen_Insane
Sep 19, 2011 15:09 |  #7
You'll have to refer to your motherboard manual, it's different for every motherboard.
Gear
1,338 views & 0 likes for this thread, 3 members have posted to it.
Latest registered member is RawBytes
1360 guests, 159 members online
