Does anyone know if the correction capabilities of Canon's Digital Photo Professional (DPP) software can be used in some way to correct distortion, vignetting, CA and color blurring in non-Canon optics such as Tamron or Sigma?
LudwigVB Senior Member ![]() 408 posts Joined Nov 2010 Location: Sydney, Oz More info | Sep 17, 2011 16:58 | #1 Does anyone know if the correction capabilities of Canon's Digital Photo Professional (DPP) software can be used in some way to correct distortion, vignetting, CA and color blurring in non-Canon optics such as Tamron or Sigma?
tonylong ...winded ![]() More info | Sep 17, 2011 17:01 | #2 I don't know -- do you have a lens like that, and do you have DPP, so that you could run tests and post back and let us know? Tony
Sep 17, 2011 21:43 | #3 Good question. I do have DPP, which is the reason for my question, because I know there is data available to it from EXIF info from, many Cannon lenses but I'm not aware of such data coming from other lenses. Nor am I aware of DPP providing for any correction parameters that could be applied manually.
MGiddings Photography Senior Member ![]() 964 posts Likes: 9 Joined Mar 2010 Location: Norwich, Norfolk, UK More info | Sep 18, 2011 16:40 | #4 |
tzalman Fatal attraction. ![]() 13,491 posts Likes: 205 Joined Apr 2005 Location: Gesher Haziv, Israel More info | Sep 18, 2011 17:05 | #5 I know there is data available to it from EXIF info from, many Cannon lenses but I'm not aware of such data coming from other lenses. The correction data for supported Canon lenses is not in the Exif; it is in DPP and its use is triggered by the lenses' numerical designations which are in the Exif. Some Sigma lenses have numbers that are the same as numbers used by Canon lenses and this will fool DPP into applying the corrections for a Canon lens, but they will be "incorrections", as it were. Elie / אלי
junkbot Hatchling 6 posts Joined Nov 2011 More info | Dec 09, 2011 07:16 | #6 I don't suppose there's a list out there of which Canon (and non-Canon) lenses work?
yb98 Goldmember ![]() 2,586 posts Likes: 26 Joined Feb 2003 Location: Paris More info | Even my canon 70-200 4L is not supported. So I would be surprised if other non canon lenses were supported... Best DPP Threads
Dec 09, 2011 11:16 | #8 Here's an older list of lenses that DPP supports. I'm not sure if it has changed.
ettlz Senior Member 254 posts Likes: 12 Joined Feb 2007 More info | Feb 18, 2012 06:51 | #9 Getting DPP's lens aberration correction to work with my non-Canon lens # [B]yum install perl-Image-ExifTool[/B] $[B] exiftool -LongFocal=55 -ShortFocal=17 -LensType='Canon EF-S 17-55mm f/2.8 IS USM' [I]working-copy[/I].CR2[/B] Lo and behold, it worked! Aberration correction was enabled, and it cleaned up the CA marvellously. The following are screen-shots at 100% from DPP. The image was taken on a Canon EOS 60D using a Tamron 17-50mm f/2.8 lens, at 17mm, aperture f/8.0. The image on the left is with no correction applied, the one on the right with CA correction set to 100. (Apologies for the cursor in the way.) Some notes:
Update, 2012-02-26 The Canon EF-S 18-200 f/3.5-5.6 IS seems to be a good substitute for the purposes of enabling lens correction for images shot with the Sigma 18-250mm f/3.5-5.6 OS. $ [B]exiftool -LongFocal=200 -ShortFocal=18 -LensType='Canon EF-S 18-200mm f/3.5-5.6 IS' [I]filename[/I][/B] Update, 2012-08-27 For the Tamron SP 70-300mm F4-5.6 Di VC USD, I use Canon's functional equivalent: $ [B]exiftool -ShortFocal=70 -LongFocal=300 -LensType='Canon EF 70-300mm f/4-5.6 IS USM' [I]filename[/I][/B] Canon EOS 60D :: Canon EOS 7D :: Canon EOS 10 :: Canon EF-S 18-55mm f/3.5-5.6 IS STM :: Manual-focus Canon EF 50mm f/1.4 USM :: Canon EF-S 55-250mm f/4-5.6 IS STM
yb98 Goldmember ![]() 2,586 posts Likes: 26 Joined Feb 2003 Location: Paris More info | Thanks for sharing. Best DPP Threads
y 1600 |
Log in Not a member yet?
Registered members may log in to forums and access all the features: full search, image upload, follow forums, own gear list and ratings, likes, more forums, private messaging, thread follow, notifications, own gallery, all settings, view hosted photos, own reviews, see more and do more... and all is free. Don't be a stranger - register now and start posting! |
Latest registered member is Irony 766 guests, 228 members online Simultaneous users record so far is 15144, that happened on Nov 22, 2018 |
