Thread started 19 Sep 2011 (Monday) 12:30
Need a good ND filter for my Tokina 11-16mm Lens
Ten ­ Ounce
Sep 19, 2011 12:30 |  #1
I purchased this ND filter from Amazon to shoot some sunset and waterfall photos. I used it this past weekend at the beach and wasn't too impressed with out the pictures came out. Is this a decent ND filter or should I be looking at something else?
http://www.amazon.com …F8&qid=13164531​31&sr=1-10 (external link)
YouTube Tutorials-https://www.youtube.co​m/user/MQuilesPhotogra​phy (external link)
Gear List & Feedback
Facebook | (external link)
Follow me on Twitter |  (external link)Website (external link)
Jon
Joined Jun 2004
Sep 19, 2011 12:33 |  #2
Yes, it's a good filter. What's wrong with your pictures? Care to post an example or two?
Jon
Cocker Spaniels
Ten ­ Ounce
Sep 19, 2011 12:37 as a reply to  @ Jon's post |  #3
I guess there really isn't anything "wrong" with it, just didn't give me the pop I was expecting. Here's a shot I took at a nearby lake a few nights ago.
https://photography-on-the.net …p=13081948&post​count=2953
I'm really trying to get that foggy water type of effect but haven't been able to get a single shot thats even close.
Sirrith
Gallery: 50 photos
Joined Nov 2010
Sep 19, 2011 12:57 |  #4
The problem isn't with the filter, its with the technique.
Your shot you linked was taken with a shutter speed of 1/15s. You aren't going to get milky water with that, you need slower exposures.
If you plan to do this during the day, you'll need a more powerful (darker) filter and a very small aperture. Its better to do it during and just before/after sunrise and sunset when the light is not as bright so you can expose for longer.
This shot for example was taken just before sunrise, and as you can see, the water is only just starting to get blurry and smooth. Shutter speed was 0.6s
HTTP response: NOT FOUND | MIME changed to 'image/png' | Redirected to error image by ZENFOLIO PROTECTED
This photo, around the same time, shutter 3.2s, water is smoother and blurrier
The longer your shutter speed, the smoother and foggier the water will be.
-Tom
Ten ­ Ounce
Sep 19, 2011 13:00 |  #5
Thanks Sirrith. So the filter I currently have would allow me to capture similar photos if I expose a bit longer?
Sirrith
Gallery: 50 photos
Joined Nov 2010
Sep 19, 2011 13:02 |  #6
Ten Ounce wrote in post #13127926 (external link)
I don't see any reason why it should not :)
Give it a try and post the results!
-Tom
Ten ­ Ounce
Sep 19, 2011 13:10 |  #7
I guess I'll be heading back to the lake this evening to give it another try!
Sirrith
Gallery: 50 photos
Joined Nov 2010
Sep 19, 2011 13:18 |  #8
If its a lake, the water may not be moving much. The reason you get milky water in photos is because of the movement of said water. If there is no movement, you will get no blur no matter how long you expose for. Try find somewhere where there are ripples or some waves, then you'll see the effect. The more the water is moving, the less you need to keep the shutter open to get the milky effect.
-Tom
Jon
Joined Jun 2004
Sep 19, 2011 13:23 |  #9
Ten Ounce wrote in post #13127779 (external link)
The other thing I see there is that stationary parts aren't really crisp. What tripod are you using? If you don't have a solid tripod, and/or you use the center column to get the height you want, you're going to get some camera shake.
Jon
Cocker Spaniels
4,690 views & 0 likes for this thread, 3 members have posted to it.
618 guests, 116 members online
