Thread started 19 Sep 2011 (Monday) 13:41
Interesting find while MA'ing some lenses
JonK
Joined Feb 2004
Sep 19, 2011 13:41 |  #1
Over the weekend I was just confirming my MA settings on my cameras on some lenses and writing them down in a place where I keep the serial #'s etc. I recently purchased a 50mm 1.4 and 50mm 1.8 and hadn't MA'd them. The 5DII benefited from a couple clicks of MA backward. The method I used for the 5DII was to set up my lens align, line it up, and take a few shots checking the DOF in the camera screen and moving the images over for comparison.
I then decided to try to MA the 7D and 50mm 1.4 with a different method. Still used the LensAlign, lined it up, tethered the 7D to my laptop and did the Quick Mode focus with tethered shooting where you zoom to infinity and then hit focus, it uses the camera to focus like ordinary (not like live view) and then click forward or back on the manual focus buttons and that indicates your MA adjustments necessary.
Thing is, my 85 1.2, 100mm, etc., all worked like this perfectly. I had repeatable results. Quick Mode focus from thethered shooting, focus a little out, click click click click, sharp focus, add MA setting of +4 or -4 depending, redo, perfect. However, when I put the 50mm lenses on, one click of the small focus adjustment button in the live view window resulted in a massive focus jump forward or backward. Like, probably the equivalent of 15 clicks on any of my other lenses.
What gives?!
7NE | 7D | 5DII | 16-35/2.8L II | 24/1.4L II | TS-E 24/3.5L II | 50/1.4 | 85/1.2L II | 100/2.8L IS | 70-200/2.8L IS II | 400/5.6L | PIXMA Pro 9500 Mark II
check my blog:
www.jonkensy.com (external link)
led ­ hed
Sep 19, 2011 13:52 |  #2
dunno, i shot my roof shingles, adjusted accordingly, and left it at that.
your method sounds too complicated. so i'm gonna forget i read this.
Rob - "a photographer is a painter, in a hurry!"
Canon 7D ~ Canon EF 70-200mm f/2.8L IS MKII ~ Canon EF-S 17-55mm f/2.8 IS ~ Canon EF 50mm f/1.8 II ~ Canon 430EX ~ Canon EF 2.0X III Telephoto Extender ~ Canon SX230 HS
JonK
Joined Feb 2004
Sep 19, 2011 14:01 |  #3
led hed wrote in post #13128201 (external link)
So why bother posting?
It's straight forward and I think it may even be how canon recommends. You just tether and use quick mode and look at the results. Hit the focus buttons on screen until its sharp. Then you know how many clicks = which way to MA. Not complex at all. Point is, on most of my lenses a click moves the focus a little bit. Yet, on my 50mm's, a click moves the focus a ton.
check my blog:
led ­ hed
Sep 19, 2011 14:04 |  #4
you are right, shouldn't have posted. but i think you can simplify your method.
someone else may have some useful advice ;)
Albert ­ Nam
Joined May 2011
Sep 19, 2011 14:13 |  #5
It may be because the 50mm has coarser increments since it does not use a true ring USM motor
Gear
JonK
Joined Feb 2004
Sep 19, 2011 14:50 |  #6
led hed wrote in post #13128274 (external link)
I do use a simpler method, this was obv... dude just read the post before posting jeez
Albert Nam wrote in post #13128329 (external link)
Could be - seems weird though - like, then, does MA adjust even work? Like if I can't focus small amounts with the manual focus buttons and those are supposedly linked to what would be a "1 MA" adjustment, does the 50mm 1.4 / 1.8 even MA adjust?
check my blog:
1,560 views & 0 likes for this thread, 3 members have posted to it.
1053 guests, 104 members online
