why does the 580EX on a 20D emit flashes when using the DoF Preview function? o_O
On another note, doesnt the 20D's built in flash emit flash when using CF 4-1 focusing method when its dark ?
CorruptedPhotographer Goldmember 1,802 posts Likes: 2 Joined Jul 2005 Location: AbuDhabi, United Arab Emirates More info | Oct 30, 2005 22:31 | #1 why does the 580EX on a 20D emit flashes when using the DoF Preview function? o_O Gear List
PacAce Cream of the Crop 26,900 posts Likes: 40 Joined Feb 2003 Location: Keystone State, USA More info | Oct 30, 2005 22:52 | #2 The 580EX (as well as the 550EX and the 420EX) emits a burst of pulses (referred to a modeling light) when you press the DOF preview button so that you can see what the DOF of the scene looks like. If you have the flash on, the assumption is that it's already dark to begin with. When you close down the aperture of the lens for the DOF preview, it's going to look even darker in the viewfinder so the burst of flash light pulses helps you see the image through the viewfinder a lot better. ...Leo
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Oct 31, 2005 02:01 | #3 The answer to both is "because that's the way it's designed". Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
robertwgross Cream of the Crop 9,462 posts Likes: 3 Joined Nov 2002 Location: California More info | I suppose that Canon could have put an extra control button on the camera that is named "activate external flash modeling light." However, that would cost a few cents extra.
RenéDamkot Cream of the Crop 39,856 posts Likes: 8 Joined Feb 2005 Location: enschede, netherlands More info | Oct 31, 2005 02:31 | #5 The 580 EX has a CFn to change this: CFn 10 sets the modelling light to the test button of the flash. You can also switch the ML off alltogether with CFn. 6. It's all in the manual... "I think the idea of art kills creativity" - Douglas Adams
CorruptedPhotographer THREAD STARTER Goldmember 1,802 posts Likes: 2 Joined Jul 2005 Location: AbuDhabi, United Arab Emirates More info | Oct 31, 2005 03:28 | #6 Bob, I get the feeling you are explaining another feature or use of the action. Gear List
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | CorruptedPhotographer wrote: tim, the answer is both? both what? The answer to both of your questions is "because that's the way Canon made them". Ours is not to question why... Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
CorruptedPhotographer THREAD STARTER Goldmember 1,802 posts Likes: 2 Joined Jul 2005 Location: AbuDhabi, United Arab Emirates More info | Oct 31, 2005 03:43 | #8 Im not questioning why Canon chose to include these features. Im trying to comprehend what the features are used for to take advantage if them. Gear List
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Oct 31, 2005 03:53 | #9 The first, I guess it's so you can see what you're trying to take a photo of. I used mine as a torch this past weekend. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
RenéDamkot Cream of the Crop 39,856 posts Likes: 8 Joined Feb 2005 Location: enschede, netherlands More info | Oct 31, 2005 04:22 | #10 The modeling light is the stroboscopic series of flashes (70Hz for 1 second) you see when you press the DoF preview button "I think the idea of art kills creativity" - Douglas Adams
robertwgross Cream of the Crop 9,462 posts Likes: 3 Joined Nov 2002 Location: California More info | I would explain it similarly. A modeling light on an external flash unit works similarly to the modeling light on a studio strobe. It is simply a temporary test light that will illuminate the subject from the exact same angle as the real light. If you were set up in a studio with lights A and B, you might want to fire off the modeling light to see that both A and B were really ready to go and aimed correctly. The light intensity will seem to be low or flickering, because you don't need the real full flash pop for test purposes.
CorruptedPhotographer THREAD STARTER Goldmember 1,802 posts Likes: 2 Joined Jul 2005 Location: AbuDhabi, United Arab Emirates More info | Oct 31, 2005 13:36 | #12 Wow thats wonderful! Gear List
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Oct 31, 2005 13:44 | #13 Three things: Jon
robertwgross Cream of the Crop 9,462 posts Likes: 3 Joined Nov 2002 Location: California More info | I can speak to the 550EX, and I suspect that the 580EX is similar.
CorruptedPhotographer THREAD STARTER Goldmember 1,802 posts Likes: 2 Joined Jul 2005 Location: AbuDhabi, United Arab Emirates More info | Oct 31, 2005 13:49 | #15 thanks again everyone! If it fired at full output, it'd be over in a, you should pardon the expression, flash. By firing at a lower intensity, but repeatedly, it gives you something that looks like continuous lighting, so you can grasp what it's going to look like. The modeling flash is intended to put some light out for your eyeball to judge, and your eyeball doesn't work as fast as a shutter.
| Latest registered member is Monkeytoes 1364 guests, 175 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
