Thread started 21 Sep 2011 (Wednesday) 13:23
HS Girls Volleyball - Freshman
tmalone893
Gallery: 54 photos
Sep 21, 2011 13:23 |  #1
This was the first time for me to photography HS volleyball. It was much harder then what I tought it was. The speed was a little difficult for me at first and my timing is a little slow, will work on that for the next game. Would appreciate any comments/help from you Volleyball shooters. I didn't get any net shots. The girls were freshman and none of them set up for a spike. They jumped for the blocks but the shots never came from close up.
1.
HTTP response: NOT FOUND | MIME changed to 'image/png' | Redirected to error image by ZENFOLIO PROTECTED
2.
3.
4.
5.
MaxPreps Profile (external link)
https://www.instagram.​com/theronmalone/ (external link)
Damadsetta
Sep 21, 2011 13:28 |  #2
Note: 2 and 3 are the same shot.
Shooting the lower levels is frustrating at times due to the lack of attacking as you said. I think you did well, 4 is a good capture and is cropped well. I would try to not cut off the legs where you did in the last one. If you go up higher (like you did in 4) it looks good, but if you cut if off below the knees you might as well get the whole body in there.
You have a key concept down: ball and face in the frame.
tmalone893
Gallery: 54 photos
Sep 21, 2011 13:32 |  #3
Damadsetta wrote in post #13139970 (external link)
I believe I fixed the duplicate shots. Thanks for the advice.
Questions on shooting the spike shots when the net is between you and the player, do you focus before the shot or do you let the AF do its job? I tried on some of the blocks but the net would through the focus off. Could be that they couldn't jump that high.
Damadsetta
Sep 21, 2011 13:50 |  #4
tmalone893 wrote in post #13139994 (external link)
I have very rarely prefocused on any spot. Sometimes I have focused on the net before the play, but only if I had enough distance between myself and what I was shooting so that there are no DOF issues. To fix the problem you mentioned, you have to work on positioning yourself. For most plays in volleyball, that blocker in the way is going to be a big issue. Find places on the court where you aren't obstructed. For an OH, shoot on line with the hitter behind the baseline, most blockers do not get all the way to the antenna. For MH's shoot even the baseline from either side, there is often a gap between the middle blocker and the other blocker. Also, be prepared to miss shots in this sport, just the nature of the game!
NManuel01
Joined Aug 2011
Sep 21, 2011 17:00 |  #5
Nice set, I'm going to my nieces game next week I'll post my pics for cc.
Good info to take with me here.
6D, 70-200 MKii F2.8, Tamron 24-70mm, Canon 40mm
Eos M, 18-55mm, 20mm
Alienbee 800, Canon 430exii, Canon 90ex
Nukehed
Gallery: 10 photos
Sep 21, 2011 22:44 as a reply to  @ NManuel01's post |  #6
I was always told if you have to crop out limbs, that you crop between joints...not at joints.
"There are four boxes to use in the defense of liberty: soap, ballot, jury, ammo. Use in that order."- Ed Howdershelt
My website (external link)
Going ­ Baroque
Sep 21, 2011 23:42 as a reply to  @ Nukehed's post |  #7
Aside from a few that could have been white balanced a little better, these look really good. In fact, the ones with good action are pretty obvious, and I doubt someone with more experience would have done much better (aside from maybe having more of the keepers per game).
As for tips, there really isn't much to say about shooting volleyball. The game is so chaotic that if you position yourself to get a good shot of one person, you'll likely miss a bunch of other good shots of someone else because of things/players in the way, so I try not to over-think it. For example, if you are sitting behind the team that you're covering, you'll likely get great shots of the setter, but you'll miss all the blocks. Just keep moving around and you should be okay.
Fligi7
Sep 22, 2011 12:19 |  #8
The key is definitely to keep moving if you're not shooting for a particular team. Use the whole court. It's actually pretty strenuous to shoot a volleyball game if you want to get a good assortment of shots, not just 300 shots of the same two blockers or attacker.
2,081 views & 0 likes for this thread, 6 members have posted to it.
758 guests, 125 members online
