texshooter wrote in post #13147533
Does the name of the PCb B1600 have anything to do with watt/seconds? I understand the Einstein and the B1600 have the same maximum light output. Why is Einstein 640w/s and the B1600 1600w/s. Or do they not pump out the same energy?
As has been said above, you need to look at specifications and not just model numbers.
why can't strobe manufacturers use the same language when it come to measuring light output. When I want to know how much light comes out of the bulb, I don't care about how much energy the bulb sucks from the battery. I don't care about the relative brightness of the bulb compared to other manufacturers' bulbs. All I care about is how much light comes out--period. I feel like I can't trust the specs on different strobes without first doing my own tests.
A basic fact that you need to understand is that Watt-second values have nothing to do directly with the light output level of a flash unit. The Watt-second number (the same as Joules) is simply a measurement of how much energy is stored in the capacitors within a flash unit's power supply.
You will find that if you five different manufacturer's lights - all "rated" at 640 Watt-seconds - the light they put on the subject could be different from each one of them. Why? It's because of variations in the internal circuitry and wiring in the units, differences in the design of the flash lamps themselves, and differences in the reflectors that control where the light goes.
Most of the low-end studio flash equipment manufacturers do not do what PCB does with the AlienBees units' specifications. PCB actually lists what a light meter would read with their units set at certain power levels, with specific reflectors or other light modifiers used, and with the meter located at a specific distance from the flash. This is information that is useful.
when I say my car goes a max of 120 miles/per hour, I don't mean that it goes a speed that is perceptively similar to another car's speed while using twice as much fuel. I mean it goes 120mph. But with strobes, you have to take a class in the theory of relativety to understand what's going on.
PCB is very truthful about their specifications and explains exactly what their numbers mean.
By the way - the abbreviation Watt-seconds is Ws or W-s and is not written with a slash (such as W/s), as the slash indicates a division of one number by another. The thread title is also wrongly written with slashes.
