Thread started 24 Sep 2011 (Saturday) 17:12
Canon Extender on 70-200 Is f/2.8II
RLipp69
Sep 24, 2011 17:12 |  #1
How is the quaility of photos useing the Canon Extender EF 1.4 or 2X III on the canon 70-200f2.8 IS II? Is it worth the $$? Thanks
Canon 5DMKIII, 40D,EF 70-200 F/2.8L IS II,24-70 F/2.8L,35mmF/1.4[COLOR=red]L, EFS-580EXll.Pcket wizzard mini & Flex,Bees and beauty dish
huntersdad
Sep 24, 2011 19:54 |  #2
1.4xIII is only slightly better than the MkII. 2xIII is big time better.
Facebook (external link)
http://WWW.BLENDEDLIGH​TPHOTOGRAPHY.COM (external link)
1DxIII x 2 / 24 1.4 II / Sigma 35 1.4 / 85 1.4L / 70-200L II / 300 II / AD600Pros
Overread
Gallery: 12 photos
Sep 24, 2011 20:01 |  #3
The 1.4TC (either MII or MIII) will give you a:
98-280mm f4 IS L lens and the image quality reduction will be minimal generally speaking. If stopped down a little chances are you'd not even be able to tell that the TC is added (Image quality wise).
the 2*TC (MII or MIII) will give you a:
140-400mm f5.6 IS L lens which is on par, image quality wise with the 100-400mm; with both showing significant improvements in sharpness when stopped down to around f7.1/f8.
In general it depends what you are after, I personally consider the 1.4TC to be well worth adding in any situation that calls for it; whilst the 2*TC is also valid to add if you want that 400mm range whilst also keeping a very usable level of image quality (it won't be beating a 400mm f5.6, but then the 100-400mmL can't either).
The 70-200mm f2.8 IS L MII is one of the few zooms that I rate capable of taking a 2*TC and retaining a usable image quality
Tools of the trade: Canon 400D, Canon 7D, Canon 70-200mm f2.8 IS L M2, Sigma 120-300mm f2.8 OS, Canon MPE 65mm f2.8 macro, Sigma 150mm f2.8 macro, Tamron 24-70mm f2.4, Sigma 70mm f2.8 macro, Sigma 8-16mm f4.5-5.6, Raynox DCR 250, loads of teleconverters and a flashy thingy too
My flickr (external link)
Princemicki
1 post
Joined Sep 2009
Sep 29, 2011 14:39 |  #4
I love the 2x III, but I lost the end cap that fits the lens. Anyone know what it's called and where I can find one? It is not the same as a body cap.
JohnJ80
Sep 29, 2011 16:08 |  #5
Let me put it this way, using my 1.4x II, I basically no longer use my 300 f/4L IS. I get the same or better IQ, I get the versatility of a zoom in that range and I get better IS.
J.
Obsessive Gear List
"It isn't what you don't know that gets you in trouble; it's what you know for sure that isn't so." - Mark Twain
Snydremark
my very own Lightrules moment
Gallery: 58 photos
Sep 29, 2011 16:15 |  #6
I found the results from using the Mk2 + 2x TC to be quite disappointing and no where near as good as my 100-400. I didn't bother trying the 1.4 TC
- Eric S.: My Birds/Wildlife (external link) (7D MkII/5D IV, Canon 10-22 f/3.5-4.5, Canon 24-105L f/4 IS, Canon 70-200L f/2.8 IS MkII, Canon 100-400L f/4.5-5.6 IS I/II)
Overread
Gallery: 12 photos
Sep 29, 2011 16:20 |  #7
Snydre that is surprising because most of the reviews I've read have the two setups fairly evenly matched. It could be that you've got some unholy uncommonly good example of the 100-400mm (I've seen some strange ones, esp one which was far below normal sharpness at its short end, but a bit above average at the long end)
https://photography-on-the.net/forum/showthre​ad.php?t=869226
Is a comparison I've often sourced for comparing the two lens approaches - are you saying that your 100-400mm is equal to or better than those results or that your 70-200mm results were lesser (could always be that the TC + lens were slightly missmatched with calibrations and resulted in less than ideal performance)
Snydremark
Gallery: 58 photos
Sep 29, 2011 17:22 |  #8
Overread wrote in post #13183669 (external link)
Yes. I took the "pump" and the 70-200 + TC (2, different copies even) out, set up a tripod and took a couple of shots with both. Manually focused in Live View for both, so no AF weirdness; both set to f/5.6 because that's how I shoot the 100-400 98% of the time.
Point of focus for both was the single, green leaf at the top of the vine; near the bottom, center of the trunk. With both copies of the TC this was the best focus I could get.
70-200 MkII + 2x TC MkIII:
IMAGE: http://farm6.static.flickr.com/5086/5329626868_bbca64ec7e_b.jpg
IMAGE LINK: http://www.flickr.com/​photos/snydremark/5329​626868/  (external link)
70_200MkII_2.0x-0455 (external link) by Guideon72 (external link), on Flickr
Full Size (external link)
100-400:
IMAGE: http://farm6.static.flickr.com/5047/5329015605_d334ca01df_b.jpg
IMAGE LINK: http://www.flickr.com/​photos/snydremark/5329​015605/  (external link)
100-400 (external link) by Guideon72 (external link), on Flickr
All of that said; yes, I think I must be in the minority or just REALLY picky about my results...others seem to have better success. But I think it's good to illustrate how every person should evaluate these things with their own hardware, since results can and do vary significantly.
Overread
Gallery: 12 photos
Sep 29, 2011 17:32 |  #9
Hmm the 100-400mm is reported to retain the edge at the wide open, but only just; that first shot does look poor and the difference between the two is very noticeable. I wonder if it wasn't a case of backfocusing on the 70-200mm + TC combo which throw the tree body out of focus or simply a calibration error between the two units which resulted in less than ideal performance.
bobbyz
Sep 29, 2011 17:38 |  #10
I need to test 2xTC II on my 70-200mm f2.8 IS II. My 100-400L was real good. I don't have it right now to compare.
Fuji XT-1, 18-55mm
vitacura
Sep 29, 2011 17:49 |  #11
I have been contemplating picking up the 2x III to pair with my 70-200mm II. Most of the reviews and thoughts I have read on this combo online is positive.
Gear & Feedback
Snydremark
Gallery: 58 photos
Sep 29, 2011 17:51 |  #12
Overread wrote in post #13184006 (external link)
My suspiscion is that my body and lens are JUST within tolerances, together; and throwing additional elements in there is just enough to throw the whole shebang out of whack. But, since I already have the 100-400, it wasn't worth my while to struggle with shippinv things around to figure that out.
fitshaced
Joined Jul 2011
Sep 29, 2011 18:25 |  #13
Here's one I took. A long exposure with 70-200 2.8 II with X2 MK III.
Might not be very telling as its a long exposure but I took this without a remote so not as sharp as it could be.
IMAGE: http://farm7.static.flickr.com/6175/6185125792_6387fcaa86.jpg
IMAGE LINK: http://www.flickr.com/​photos/picsbykev/61851​25792/  (external link)
http://www.flickr.com/​photos/picsbykev/ (external link)
Silverfox1
Sep 29, 2011 18:44 as a reply to  @ Snydremark's post |  #14
I have to agree with Snydremark & his opinions.
When i conducted testing various extenders with the 70-200MKII mated with the current generation of crop bodys the 100-400 UY sharp copy i had at the time produced better IQ at 400/f5.6 versus the 70-200 MKII at 400/f8.0 with the 2X TC`s.
IMO the only bodys mated to the 70-200MKII + the Canon 2X III extender that come close or equal to the 100-400 zoom at 400/f5.6 are the sensors in the 1D MKIV, 1DsMKIII, & 5D MKII. These bodys still wont beat the IQ of the 400/f5.6 bare prime and until i see someone that claims they do post back to back 100% crops of the same subject matter, same exact distances, camera settings, tripod mounted, Liveview, delay timer, etc. my personal opinions wont change. And im not talking about dollar bills or test charts indoors. Also IMO stationary subject captures outdoors from 25ft. at 400mm with 100% crops is my preferred testing method. By no means am i in any way attempting to tell folks how to spend their hard earned money but only posting my personal findings.
I have seen some very nice photos below by Cicero using the 1D MKIV & 5D MKII mated to his 500/f4 IS + various brand 2X extenders but this thread pertains to the 70-200MKII.
https://photography-on-the.net …p=12445643&post​count=1529
https://photography-on-the.net …p=12238874&post​count=1333
Regards, Ron ;)
Silverfox1 POTN Feedback / TC Extender Tests / Gear List
Overread
Gallery: 12 photos
Sep 29, 2011 18:54 |  #15
I think anyone would be shocked if the 70-200mm MII and 2*TC could come close to the 400mm f5.6 prime lens on its own. I think its just asking way too much of the optics with the TC involved; Even the designed for 100-400mm can't do that and I suspect the only zoom that would is a 200-400mm (ie cutting out part of the zoom range).
4,221 views & 0 likes for this thread
Latest registered member is pdomag
813 guests, 256 members online
