Thread started 26 Sep 2011 (Monday) 20:45
35L on 5D2
MFG
Sep 26, 2011 20:45 |  #1
Hi,
I tried a 35L and use it on a 5D2 for the first time.
Setting i normally used and prefer,
Av mode, auto ISO.
I tend to get shutter speed range between 1/30-1/40. Is there a way to increase this range of shutter speed?
i know that in Av mode, fixing ISO to say 1600 can bump up the shutter speed. but i like to vary my ISO.
Hence, is there a way to increase this range of shutter speed?
cheers,
Scott
AIPP Accredited (Australia), WPJA
Professional Wedding, Newborn and Family Photographer
https://www.scottgohph​otography.com.au (external link)
https://www.facebook.c​om/ScottGohPhotography (external link)
https://www.scottgohph​otography.com.au/blog (external link)
https://www.scottgohph​otography.com.au/babie​s-and-children/ (external link)
cedew
Sep 26, 2011 20:48 |  #2
What aperture are you shooting at?
Higgs ­ Boson
Sep 26, 2011 20:49 |  #3
Lower the aperture number. Get more light on your subject. Raise your iso. Auto iso range on the 5dii is not wide.
A9 | 25 | 55 | 85 | 90 | 135
mike ­ cabilangan
Sep 26, 2011 21:01 |  #4
not with AUTO ISO.
i still wish Canon would let users set a range for auto ISO (like if i want ISO 400 to ISO 800 ONLY)
that will ensure i have a minimum shutter speed but still with the flexibility of auto ISO
camera bag reviews (external link)
flickr (external link)gearLust
MFG
Sep 26, 2011 21:35 |  #5
cedew: i shoot aperature range 1.4-2.8
mike cabilangan: yes, i agreed with you. too bad, i love to use auto ISO. works well with 70-200 but not with this prime lens. Indoor, i have to set ISO to 1600 to upp my shutter speed. annoying as Av cannot be used indoor. i always have motion blur due to 1/30-1/40.
cheers.
Scott
cedew
Sep 26, 2011 21:39 |  #6
If you're wide open at 1/30-1/40 and ISO1600, but don't want to go higher than 1600 or use faster shutter speeds, there is no more pixie dust left. :)
ni$mo350
Sep 26, 2011 21:44 |  #7
Shoot manual :)
-Chris-Website (external link)|| (external link)Facebook (external link)|| My Flickr (external link)|| Follow me!!! 500px (external link) || (external link) 5D mkii || 35L || 70-200 f/2.8L IS MKII || My bank account hates you all :cry:
john_galt
Joined Mar 2011
Sep 26, 2011 21:58 |  #8
cedew wrote in post #13168124 (external link)
pixie flash :lol:
Gear: 5d iii, 17-40mm l, 24-70mm ii, 35mm 1.4 l, 50mm 1.4, 85mm 1.8, 135mm l, 70-200mm ii l, 600ex-rt
kin2son
Joined May 2011
Sep 26, 2011 22:22 |  #9
ni$mo350 wrote in post #13168159 (external link)
Shoot manual :)
exactly;)
5d2 + 35L with auto iso?? what a waste of such a fine glass....
5D3 Gripped / 17-40L / Σ35 / 40 Pancake / Zeiss 50 MP / Σ85 / 100L Macro / 70-200 f2.8L II IS / 430 EX II / 580 EX II / Canon 2xIII TC / Kenko Ext. Tubes
EOS M / EF-M 18-55 / EF-M 22f2 / Ricoh GR aka Ultimate street camera :p
Flickr (external link) | My Images on Getty®‎ (external link)
cedew
Sep 26, 2011 22:24 |  #10
^^^ Please explain.
kin2son
Joined May 2011
Sep 26, 2011 22:53 |  #11
cedew wrote in post #13168477 (external link)
^^^ Please explain.
Well i just never trust auto ISO, I don't think it's accurate either.
Also what auto iso does is to make sure the shot is of right exposure, but sometimes that might not be what you want.
I can understand why people use AV and TV, and auto iso is fine if you are a beginner with a rebel or something. But on a pro body? i just wouldn't recommend, it hurts me a little bit inside...:cry:
cedew
Sep 26, 2011 23:20 |  #12
In theory, it's an excellent feature for n00bs and pros alike, provided you trust the meter and the feature works like it should.
kin2son
Joined May 2011
Sep 26, 2011 23:37 |  #13
MFG wrote in post #13168093 (external link)
cheers.
Scott
Hi Scott, can I just ask when you use auto iso, what was the aperture and iso value? Was the result correctly exposed?
If the shutter was 1/30, then you must be in a pretty dark room.
justaf ­ IREMAN
Sep 27, 2011 00:19 |  #14
MFG wrote in post #13167780 (external link)
Hi,
Av mode, auto ISO.
cheers,
Scott
Only if you mount a longer FL lens.
With auto ISO on AV, the camera will pick the lowest shutter speed based on your mounted lens and selected aperture. So, if you've got a 100mm mounted it will choose around 1/100 of a second, the aperture you selected and the appropriate ISO to balance the exposure. (There are other factors, but you get the idea)
Personally, 1/30 on a 35L is plenty fast to stop camera shake with proper technique. But obviously not appropriate for fast moving subjects. Then you must manually select the ISO.
current gear...1DIII, X-E1, X-PRO 1, X100, Lumix LX5, Fujinon 35 1.4, 85LII, 430EXII, 430EX....
past canon gear....XS, 7D, 2 5DII, 2 1DIII, , 18-55IS, 24-70L, 85 F1.8, 85LII, 35F2, 35L, 24L, 200 F2L, 580EXII....
MFG
Sep 27, 2011 00:24 |  #15
kin2son wrote in post #13168980 (external link)
In Av mode, when i used auto ISO, the exposure are mostly correct. In indoor, i just shot a wedding in a hall, shutter is around 1/30-1/40, aperture is about 1.4-2.8, Auto ISO, i can see that the ISO tend to fluctuate between 100-800 max (maybe 1600). I am not sure why the ISO does not go up to 3200. It does go up to 3200 when I used my 70-200II.
Exposure is always correct.
Scott
8,363 views & 0 likes for this thread, 20 members have posted to it.
35L on 5D2
Latest registered member is EBiffany
959 guests, 111 members online
