I did a quick search but couldn't find a straight answer.
How do lenses determine the actual distance of the object it is focusing on? like on the screen of the lens.
Mike ugly when I'm sober More info | Sep 27, 2011 05:00 | #2 It uses magic www.mikegreenphotography.co.uk
Brian_R Goldmember 2,656 posts Likes: 8 Joined Aug 2010 More info | Sep 27, 2011 07:09 | #3 no it is magic that link is a lie.
joebob23 Member 83 posts Joined Jul 2007 Location: Raleigh More info | Sep 27, 2011 07:31 | #4 Not sure what you mean by "on the screen of the lens". Are you asking about the distance reported in exif data, or the focus index on the lens itself?
tomj Senior Member 706 posts Likes: 61 Joined May 2010 More info | Sep 27, 2011 08:53 | #5 If Mike's link didn't confuse you enough, try this:
Mark1 Cream of the Crop 6,725 posts Likes: 7 Joined Feb 2008 Location: Maryland More info | Sep 27, 2011 10:03 | #6 Its a trick question!!! The lens does not determine anything. The part that makes the decision is in the camera body.
amfoto1 Cream of the Crop 10,331 posts Likes: 146 Joined Aug 2007 Location: San Jose, California More info | Sep 27, 2011 11:42 | #7 Yeah, that's true... It's the camera that focuses the lens in most modern cameras... Alan Myers
Snydremark my very own Lightrules moment More info | Sep 27, 2011 11:54 | #8 Mark1 wrote in post #13170863 Its a trick question!!! The lens does not determine anything. The part that makes the decision is in the camera body. I don't think that's exactly true; if you don't have a lens that relays distance info to the camera, then the data isn't recorded in EXIF...so, most (anyway) of the consumer grade lens/body combos will not include that info. - Eric S.: My Birds/Wildlife
Mark1 Cream of the Crop 6,725 posts Likes: 7 Joined Feb 2008 Location: Maryland More info | Sep 27, 2011 12:59 | #9 The question was not how to record the info. The question was how the lens determines the distance. It simply does not. The AF system in the body tells the lens to adjust till it sees the maximum amount of contrast it can obtain. The lens makes no decisions itself. However, The lens will report its position and that can me calculated into a distance.
Sep 27, 2011 13:04 | #10 joebob23 wrote in post #13170335 Not sure what you mean by "on the screen of the lens". Are you asking about the distance reported in exif data, or the focus index on the lens itself? If the data reported in exif: I'm guessing that there is some sort of communication between camera and lens that relates raw data about the focus element position, which then gets converted to text and embedded in the exif data at time of record. For example: say actual focus element has 10 positions, the first would be the minimum focus distance of 10', second position at 20', etc., the last being infinity. The lens knows the position of the focussing element so it reports it back to the camera to be embedded in the exif. The camera and lens don't know the subject distance, but it knows generally where it's focussing at. If you're talking about the focus index on the lens itself: When they engineer the lenses, they know the focus distance based on calculations of the glass curvature, refraction, etc. Based on that, they know where critical sharp focus will occur (distance-wise) given a specific position of the focussing element in the lens. They can then put distances on the focus index of the lens based on where the focussing elements position is given a certain focus ring position. I meant the focusing screen on the lens (ex: 1.5m to infinity)
Snydremark my very own Lightrules moment More info | Sep 27, 2011 13:06 | #11 Mark1 wrote in post #13171645 The question was not how to record the info. The question was how the lens determines the distance. It simply does not. The AF system in the body tells the lens to adjust till it sees the maximum amount of contrast it can obtain. The lens makes no decisions itself. However, The lens will report its position and that can me calculated into a distance. Gotcha; that makes more sense. Thanks! - Eric S.: My Birds/Wildlife
Virto Goldmember 1,647 posts Likes: 2 Joined Nov 2010 Location: Elgin, IL More info | Sep 27, 2011 13:08 | #12 amfoto1 wrote in post #13171293 Canon DSLRs use Phase Detect for most focusing. Models with Live View switch to Contrast Detect when in that mode... it's slower but can be more accurate. Oddly enough, the 40D does not. When in live view, using autofocus lowers the mirror, turns off the LCD and focuses the lens with phase detect. Then it lifts the mirror and turns the screen back on. Kelly - EOS 5D - EOS 40D - Rebel XS - EOS 10D - EOS 1D - SX230 - AE-1 - OM-1n - Minolta Himatic7 - EOS-1N
Snydremark my very own Lightrules moment More info | Sep 27, 2011 13:09 | #13 b_ron wrote in post #13171670 I meant the focusing screen on the lens (ex: 1.5m to infinity) I kinda thought it was some sort of light that is relayed through the lens, hits the object in focus, brings it back to lens or body. Reading those links at the moment... So, that's related to the info in Mark's responses. The manufacturer knows that at "position x" the lens is focused at APPROXIMATELY "y distance"; so they put those markers on there. That scale is just a rough approximation of how far out the lens is focused and not anywhere close to exact measurements. - Eric S.: My Birds/Wildlife
Sep 27, 2011 13:13 | #14 |
| Latest registered member is EBiffany 1601 guests, 98 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
