to power 2 strobes... u know the cheap 50$ strobe with a stand that u usually have them plug in to your ac outlet at home... ?
could i use the battery of my car?
thanks
ccc_javier Goldmember 1,378 posts Joined Aug 2008 Location: Miami More info | Sep 27, 2011 15:09 | #1 to power 2 strobes... u know the cheap 50$ strobe with a stand that u usually have them plug in to your ac outlet at home... ? http://somephotosmiami.com
Sep 27, 2011 15:21 | #2 My brother bought a car battery booster-box that has two AC outlets on it... You could look for one of those. •••••••
Numenorean Cream of the Crop 5,013 posts Likes: 28 Joined Feb 2011 More info | Sep 27, 2011 15:24 | #3 Cheapest? Some hamsters in a turbine. Won't charge very fast though.
Sep 27, 2011 15:58 | #4 nrowensby wrote in post #13172329 My brother bought a car battery booster-box that has two AC outlets on it... You could look for one of those. ![]()
dmward Cream of the Crop More info | Sep 27, 2011 17:02 | #5 Its very likely that the DieHard device doesn't include a pure sine wave inverter. David | Sharing my Insights, Knowledge & Experience
CurtisN Master Flasher 19,129 posts Likes: 11 Joined Apr 2005 Location: Northern Illinois, US More info | Sep 27, 2011 17:22 | #6 ccc_javier wrote in post #13172267 to power 2 strobes... u know the cheap 50$ strobe with a stand that u usually have them plug in to your ac outlet at home... ? The cheapest way to power them is to plug them into your AC outlet at home. "If you're not having fun, your pictures will reflect that." - Joe McNally
Sep 27, 2011 22:19 | #7 Curtis N wrote in post #13172858 The cheapest way to power them is to plug them into your AC outlet at home. man............... http://somephotosmiami.com
Sep 27, 2011 22:27 | #8 dmward wrote in post #13172779 Its very likely that the DieHard device doesn't include a pure sine wave inverter. There has been a lot on this forum and others about potential damage to moonlights when using non-pure sine wave inverters. Proceed at your own risk. thanks for the warning http://somephotosmiami.com
5x5photography Goldmember 1,156 posts Joined Feb 2009 Location: North Carolina More info | Sep 27, 2011 23:39 | #9 I bought a Samlex 300 watt pure sine wave inverter. When I can get my car close enough I will hook the inverter to the battery. If that wont work I have a small car battery that I can put in a rolling bag (big enough for the inverter, battery, and cords) that I can bring on site. My firearms review site. http://rangehot.com/
Csae Goldmember 3,350 posts Likes: 1 Joined Nov 2008 Location: Montreal, Canada More info | Sep 28, 2011 01:24 | #10 You should know a couple things, Feel free to call me Case.
Sep 28, 2011 13:37 | #11 Csae wrote in post #13174767 You should know a couple things, 1) Pure sine waves play much better with electronics, especially cheaper electronics. 2) Car batteries are not deep cycle batteries, the difference is that they will suffer heavy memory effect and become useless much much sooner. Proper DIY projects for this sort of thing to get (reliable enuogh by DIY standards) power runs generally around 200$ all parts in, the vagabond mini is like 240$ if you are in the states its a no-brainer. Elsewhere heres some basic things to get you started: -Pure Sine wave (Samlex is generally well regarded, you'll probably want at least the 300w model as you need to check the PEAK charge) -Deep cycle batteries, these are usually SLA, pretty heavy, lots o power, they run around 30-60$ -Smart charger with trickle charging for your battery -Fuse, best is 2 fuses, one from the inverter to the strobe, and 1 from the battery to the inverter, this is even though the inverter generally already has one. -Get good Gauge wire, strobes pull ALOT of power, be safe. Talking about safety, make sure to have a switch in between the battery and inverter to be able to turn the power off whenever not in use.
| Latest registered member is semonsters 1588 guests, 139 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
