Is there a way to get your pictures from the computer back on to your SD card?
Lone-eagle Senior Member 269 posts Likes: 2 Joined Oct 2007 More info | Sep 28, 2011 10:05 | #1 Is there a way to get your pictures from the computer back on to your SD card? Dale
RTPVid Goldmember 3,365 posts Likes: 3 Joined Aug 2010 Location: MN More info | Sep 28, 2011 11:36 | #2 Use a card reader and just copy them. Tom
Sep 28, 2011 16:41 | #3 RTPVid wrote in post #13176629 Use a card reader and just copy them.
Dale
tonylong ...winded More info | Sep 28, 2011 20:19 | #4 You could try ZoomBrowser, but I don't know if it will work "backwards" with a camera like that...I don't mess with ZoomBrowser much, and have only connected a camera to a computer to do tethered shooting, so I can only suggest you poke around ZoomBrowser and see what you come up with! Tony
tzalman Fatal attraction. 13,497 posts Likes: 213 Joined Apr 2005 Location: Gesher Haziv, Israel More info | Sep 29, 2011 06:16 | #5 AFAIK, a card reader is the only way. But you should be aware that if the files have been altered in any way, including headers changed, the chances that the camera will display them are slim. Elie / אלי
Card reader works just fine Thanks to all Dale
D.Vance Goldmember 4,163 posts Likes: 12 Joined Jan 2011 Location: VA More info | Sep 29, 2011 11:43 | #7 Open My Computer > Sd card and drag from computer over to the card. A tip: always "safely remove hardware" to avoid corruptIng some files. I wonder if the video editors on The Titanic ever went, "Sorry, I can't right now. I'm busy synching the Titanic..."
JWright Planes, trains and ham radio... 18,399 posts Likes: 35 Joined Dec 2004 More info | Why would you want to? That's going backwards... John
funphotoexpress Mostly Lurking 18 posts Joined Aug 2011 More info | Sep 29, 2011 18:33 | #9 Lone-eagle wrote in post #13176184 Is there a way to get your pictures from the computer back on to your SD card? wow
funphotoexpress Mostly Lurking 18 posts Joined Aug 2011 More info | Sep 29, 2011 18:35 | #10 Lone-eagle wrote in post #13176184 Is there a way to get your pictures from the computer back on to your SD card? just do the opposite of what you did before
tonylong ...winded More info | Sep 29, 2011 20:24 | #11 JWright wrote in post #13183246 Why would you want to? That's going backwards... funphotoexpress wrote in post #13184232 wow There are various reasons why someone might want or need to do this. The OP may have been using the Canon Utilities software with the camera plugged into the computer, which would be problematic. But, with a card reader it's doable. And, if you have good reason, well, what's to criticize or question Tony
MTStringer Goldmember 4,652 posts Likes: 6 Joined May 2006 Location: Channelview, Tx More info | Sep 29, 2011 20:34 | #12 And a SD card works great in some digital display frames.
Thanks Tony & MT Dale
WaltA Goldmember More info | Sep 30, 2011 14:02 | #14 funphotoexpress wrote in post #13184232 wow If you wanted to bring them to Costco and get them processed. Walt
WaltA Goldmember More info | Sep 30, 2011 14:05 | #15 Actually, EOS Utilities doesn't allow you to copy pictures from your PC back to your SD card. Either does Zoom browser. Walt
| Latest registered member is MWCarlsson 603 guests, 122 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
